Jenvey ITB'S Tune up .Need Help
Old Feb 17, 2012 | 02:15 AM
spo001's Avatar
Default Jenvey ITB'S Tune up .Need Help
Hi Guys
Hope this e-mail finds you well.
Tuners help K-PRO.
My car is eqiupped with a F20C K24 Conversion with 12:1 CR. At last i have managed to buy and install jenvey ITB's. I have a problem with the calibration . problem is that the car will start but stall immediately . Obviously cannot get a reading from my Wideband as it is not giving me a chance . I m working on Alpha-N and using vacuum source direct from the vacuum booster into the Map sensor. i have calibrated the TPS against the K-Pro and it is reading 2.7 on low and 97.8 on WOT.
Do i have to calibrate something else before start trying to tune ??
Problem is that i live in Malta and there is not enough tuners here who experienced setting an S2000 with ITB's.
Or if possible maybe somebody can send me a base map to start with ? My e-mail address is nicknat6@maltanet.net
I will be than great full for your help.
Thanks in advance
Nicky
Old Feb 17, 2012 | 10:03 AM
spo001's Avatar
Any Help please ??
Thanks
Old Feb 17, 2012 | 03:54 PM
wadzii's Avatar
Banned
This is a "stock" ignition map.. see how it has a steady decrease in ign timing as load goes up
This is what you'd see with ITBs. fairly flat then a "steep" drop in timing. This is because map pressure at partial throttle is much closer to atmospheric than with a typical manifold.
tx2K
Jul 12, 2018 06:32 AM
spo001
Feb 22, 2012 10:33 AM
WeezyBaby
May 4, 2007 06:19 PM
lexar13
May 3, 2005 01:04 PM
