Kpro DIY?
Old Feb 24, 2010 | 05:43 PM
JustinC's Avatar
Originally Posted by spectacle,Feb 24 2010, 09:31 AM
datalogging from the laptop
good to know, so I guess it helps with the S2000 also
Old Feb 24, 2010 | 06:39 PM
DFWs2k's Avatar
i think he was just specifying what problem he was having...
Old Feb 26, 2010 | 08:23 AM
spectacle's Avatar
Yea. Cuz it ain't fixed. More testing coming soon.
Old Feb 28, 2010 | 10:33 AM
DFWs2k's Avatar
so i'm going to try to start the kpro install today
if i just do the parts up top, replacing the valve cover and the cam trigger wheel, and maybe the IAT, will my car still function ?
should i plug in the kpro with those items installed?
the only time i will drive this before finishing the install is about 10 minutes to the shop
Old Feb 28, 2010 | 12:00 PM
JustinC's Avatar
probably won't start since you won't have the correct crank sensor or trigger,
the cam and crank sensors are the ones that have to work together to control timing
Old Feb 28, 2010 | 12:12 PM
DFWs2k's Avatar
hm, i guess we'll see...
DFWs2k's Avatar
my one friend thought that it'd just throw a code?
having trouble with this damn fuel pump install, need to go get an 8mm ratchet
Old Mar 1, 2010 | 04:00 PM
DFWs2k's Avatar
ok, so is there an easy way to scale a map for larger injectors so that i can drive it around with kpro and the larger injectors?
Clark
Apr 24, 2013 09:45 AM
john82389
Jun 20, 2012 02:42 PM
s2jerris
Sep 20, 2011 05:55 PM
XclusiveAutosports
Aug 10, 2006 01:36 PM
shotime
Oct 22, 2003 04:52 PM
