ME221
Old Jun 13, 2019 | 10:08 AM
EOE's Avatar
EOE
I must've misunderstood. Awesome to hear that idle is as good if not better and so is the drivability and awesome to hear this ECU has data logging + OEM knock sensor support. I appreciate you sharing this with us as I don't think many folks are as transparent about what they did to fix a problem or how they got something running well with whatever ECU.
This has full closed loop operation (LTFT STFT) and can use narrow band for closed loop and wideband for further tuning. Sounds like a win-win tuning solution.
Old Jun 13, 2019 | 10:29 AM
noodels's Avatar
Strapped up my narrow band sensor,thought they got hot ? have PLX also.
Would a plastic bag over it be a fire risk
Old Jun 13, 2019 | 11:12 AM
aaronyuri's Avatar
No, the narrowband sensor is removed... The harness connector is wrapped in a bag to prevent dirt and debris ingress.
Thanks! Just sharing the knowledge. I'm not a tuner - motoring is just a hobby for me.
There is one flaw I've noticed, however, which is the lack of VTEC engagement at high RPM (over 6k) under the specified TPS. There were instances where lifting off and getting back on the throttle results in the engine bogging on the low cam until the high cam engages after the TPS threshold is passed then there's a horribly unpredictable surge of power.
The good news is that I contacted ME and requested the ability to specify an RPM range where the TPS threshold is ignored and they are working on implementing it.
Old Jun 13, 2019 | 11:39 AM
EOE's Avatar
EOE
Good to know. Any word on implementing MAP pressure to control VTEC engagement? I think Doctronic and Hondata does that.
Old Jun 13, 2019 | 12:59 PM
aaronyuri's Avatar
I think that's how they will likely implement it. Not sure on that one.
Old Jun 15, 2019 | 03:22 PM
aaronyuri's Avatar
Checked my base timing today with a timing light and it was 3° too advanced. This has been corrected. More work continues slowly...
Old Jul 2, 2019 | 05:31 AM
aaronyuri's Avatar
Ignition table has been rebuilt from scratch. There's absolutely nothing left from the original tune at this point... Should've done it myself in the first place.
I received a newer firmware from ME with the VTEC changes but MEITE is refusing to parse the firmware before flashing it. It's with ME to identify and resolve what's going on.
Old Jul 3, 2019 | 12:14 PM
EOE's Avatar
EOE
Ouch and scary. Good catch.
Old Jul 4, 2019 | 08:34 AM
aaronyuri's Avatar
Indeed... This means that the "tuner's" map was going as advanced as 39° under WOT. Max advance is now 26° under WOT.
Old Jul 8, 2019 | 11:47 AM
aaronyuri's Avatar
Firmware is working and doing what it needs to do. I can now prevent the disengagement of the high cam at high RPM.
There's also a transition window that can be set (like Hondata), whereby, after passing the upper engagement threshold, you can prevent disengagement until X RPM. I currently have this at 5500 RPM. Quick breakdown of what I've set:
Primary load activation 1: 80% (load at which VTEC window is set)
RPM on: 3900
RPM off: 9500
Primary load activation 2: 20% (above this load, VTEC will always be engaged until the off RPM)
RPM on: 6000
RPM off: 5500
This means that VTEC will behave based on min TPS and MAP load much like before between 3900 and 9500 RPM. However, above 6000 RPM and 20% load, VTEC will remain engaged until engine speed decreases below 5500 RPM.
I need to figure out what the hysteresis settings are, but that's for another day.
