Need help With ecu issue please!
Old May 3, 2016 | 04:18 PM
Onizukasensei's Avatar
Default Need help With ecu issue please!
Hey guys so heres the problem im having, i just bought a 2000 ap1 with an f22c in it, it was running on the ap1 ecu but was throwing a cel for running lean p170 and p0171 as you all know this is a common problem when running an f22 on an ap1 ecu , so i went and bought an ap2 ecu took it to the dealer they swapped and programmed the ecu yesterday , i drove the car around today no cel , then i plugged in my obd2 scanner and its still showing system too lean bank 1 WTF even with the new ecu, are codes stored on a separate module? Thanks for any input
Old Aug 28, 2016 | 07:21 PM
AlexSobe614's Avatar
Have you tried a hard reset since then to clear them?
dnguyen924
Apr 28, 2016 10:51 AM
Honda_Mad
May 30, 2007 07:05 AM
