Rough idle, check engine light on
Old Mar 26, 2020 | 01:27 PM
Golfer49's Avatar
Default Rough idle, check engine light on
Have had check engine cleared several times, but keeps coming back on. Also has rough idle. Runs fine on the road
Old Mar 26, 2020 | 01:55 PM
noodels's Avatar
mark may chime in as he is reading also
any how whats the code
Old Mar 26, 2020 | 02:03 PM
engifineer's Avatar
Dont clear it, pull the code and post it and we can try to help from there
In the meantime, have you had your intake off recently? Or worked on or near the valve cover? If so a very quick check will be to look at the two small vacuum lines that run to the metal formed lines (connected together with a bracket) sitting right under where the intake tube connects to the manifold. It is very common for someone to accidentally knock one of those two lines off when working on the car and cause a vacuum leak. That would set a code and could also cause a slightly rough idle.
SumoPower
UK & Ireland Traders Forum
Jan 23, 2018 01:20 AM
Mugen_is_best
Socal Swap Meet
Jan 22, 2018 07:18 PM
slickfast
May 13, 2017 06:14 PM
theprophet36
Apr 13, 2017 06:03 PM
