S2000 FlashPro Boost Control
Old Mar 14, 2011 | 02:36 PM
Hondata's Avatar
Former Sponsor
Default S2000 FlashPro Boost Control
Good news everyone
In the past many have people have asked us when boost control will be added to the S2000 FlashPro, but because the S2000 ECU does not have a spare PWM output (like the Civic Si) we have not been able to do this.
However, we have looked closely at the S2000 ECU and found that we can modify the ECU to enable a PWM output on an unused pin. Thus you can have boost control with the S2000 FlashPro.
For S2000 FlashPro boost control you will need to do four things:
1. Send in your ECU to Hondata for modification. The form you need to fill out is found here.
2. Obtain a suitable boost control valve. If you wish you can buy one from Hondata at the same time you get your ECU modified.
3. Download and install the FlashPro beta software - available later this week.
4. Wire up the boost control solenoid as per the help file
Fine print:
- Currently only US S2000 ECUs have been tested, but this should work for international S2000 ECUs.
Old Mar 21, 2011 | 07:36 PM
Jumpman2k's Avatar
Surprised there hasn't been more response to this. Sounds great, IMO. Also, bump for Farnsworth
Old Mar 21, 2011 | 08:22 PM
GrandMasterKhan's Avatar
I'll be doing this. Can I do this before my ECU is flashed via flashpro? My car is currently not running as we are in process of an engine build, so now is a good time for my s2000 to be ECUless haha.
Old Mar 22, 2011 | 12:28 PM
Hondata's Avatar
Former Sponsor
Yes, you can do this with a stock ECU before you reflash it with FlashPro.
Old Mar 25, 2011 | 09:34 PM
so if i understand this correctly I can use this built in boost control instead of a boost controller?
Will this allow boost by gear?
Old Mar 25, 2011 | 10:33 PM
EternalLx's Avatar
Yes, but just to be very clear you still need a boost solenoid.
Yes by gear and rpm
Old Mar 26, 2011 | 08:51 AM
Gernby's Avatar
Former Sponsor
Awesome! Do you think you might be able to use this approach for nitrous control?
Old Mar 30, 2011 | 01:13 PM
My ECU is in the mail. thanks!
Old Mar 31, 2011 | 10:59 AM
spectacle's Avatar
Great news
Old Apr 6, 2011 | 01:13 AM
ghettocrxsi's Avatar
I love how they said this won't be a supported mod any time soon so I ditched my flash pro and went with kpro. And here we are 6 months later and its supported....
