Software Dyno for FlashPro users (and maybe KPro)
Old Jun 20, 2013 | 11:38 AM
  #141
deibit's Avatar
Originally Posted by Gernby
Your graphs will go up and down depending on incline / decline of the road, increased wind or rolling resistance, and obiviously changes in weight. For you guysoutside the US, there may also be differences in gearing that would throw it off. I'm not sure if you guys have the same transmission, final drive, and / or tires as the USDM AP2V2.
Hi Gernby,
in Europe our MY06+ models have the following gearing:
1. Gear 3,133
2. Gear 2,045
3. Gear 1,481
4. Gear 1,161
5. Gear 0,970
6. Gear 0,810
Reverse 2,800
Final Drive 4,100
Maybe you can add a EDM option to be able to draw "compatible" graphs?
Tires/Wheels are exactly the same as in the USA ap2 models
Our engine is the F20c (same rpm cut as the USDM AP1)
Do you need further informations?
Old Oct 14, 2013 | 09:12 AM
  #142
imstimpy's Avatar
Below is a sample output using the FlashPro datalogs in the Old and New Soft Dynos. All of the screen shots were generated using the same Datalog. Some may prefer the Excel version, since it has less "noise" in the plots, but I prefer the detail that the new version offers. It's amazing how much better of a tune you can get with the added detail.
Excel-based Soft Dyno:
.Net Standalone Soft Dyno:
Gernby, can you explain to me how you found extra resolution by going to the CAN dyno?
Old Oct 17, 2013 | 06:18 AM
  #143
Gernby's Avatar
Former Sponsor
The FlashPro datalogs may look like they are at a high sample rate, but they really aren't. IIRC, the exported datalogs have about 200 samples per second, but only a few of the columns in the log change for each record. If you study the data, you'll see that the "real" sample rate is about 20 samples per second. On top of that, the speed value is just a whole number, which only has 2 or 3 significant digits (very low resolution).
However, there is a bunch of raw CAN data flowing between the many ECU's in the car (VSA, ECM, etc.), and that data is at a much higher resolution. The speed signal that is sent by the VSA ECU is about 40 frames per second AND is a very high resolution 16 bit number (0-65000).
Old Oct 17, 2013 | 11:21 AM
  #144
imstimpy's Avatar
That makes a lot more sense. I'm familiar with the Honda-style block reads from the ECU. The logs I reviewed produced ~16 blocks of data per second; not bad, but certainly not 50Hz. Your method of bypassing the ECU in search of other sources for the critical data mitigates the low data samples. Time to bust out the VehicleSpy!
In terms of dyno resolution, or work being done, time and vehicle speed are of utmost importance. The rest, such as AFR, can be interpolated between points without much loss of detail.
Old Apr 30, 2014 | 09:42 AM
  #145
imstimpy's Avatar
If anybody attempts to use this spreadsheet with later builds of Hondata (1.6+ I think), it won't work out of the box. Hondata added "PTANK" to the logs and it shifts key values ("MAP" and "INJ") to different columns.
The easy fix is to open your CSV logs and delete the entire "PTANK" column before importing it through the software dyno. The far more complicated fix is to edit the macros, which I've done. I can further explain the macro changes, but given that nobody else has posted here I'm not sure it is worth my time to create a diff.
Old Apr 30, 2014 | 12:00 PM
  #146
odb812's Avatar
Thanks for the tip. I'll just write a script to strip the columns rather than messing with the macros.
Old May 1, 2014 | 02:49 AM
  #147
ruff1017's Avatar
Thanks Imstimpy,
Finally I made it to work.
I could not figure it out how to fix this issue for somtimes.
Yes I will appreciate very much if you can explain how to edit the macros
Cheers
Mike
Old May 1, 2014 | 06:59 AM
  #148
imstimpy's Avatar
Here is my diff. You need to go into the macro editor to find this code. All changes but the last are in BatchProcessCSV and the last change is in ImportCSV.
The important changes you need are the first two that define and set int***Idx, the next two that replace the hard-coded indices with the variable int***Idxs, and finally the last that removes "PTANK" from the CSV. If you want to keep it really simple, all you need to do is replace varInput(6) with varInput(7), varInput(11) with varInput(12), then remove "PTANK" from the CSV. There are two additional changes with intExtraRows and lngLineCount that alter the consistency of the graphing and they are optional.
Code:
--- original.txt	2014-05-01 09:35:18.713136991 -0500
+++ updated.txt	2014-05-01 09:54:18.741136981 -0500
@@ -297,6 +297,8 @@
     Dim blnSkipShortRuns As Boolean
     Dim blnAlreadyAskedAboutShortRuns As Boolean
     Dim intMaxRPM As Integer
+    Dim intTPedalIdx As Integer
+    Dim intINJIdx As Integer
     On Error GoTo ErrHandler
@@ -321,7 +323,17 @@
     strFileHeader = objInputTS.ReadLine
     strFileHeader = strFileHeader & vbNewLine & objInputTS.ReadLine
-    strFileHeader = strFileHeader & vbNewLine & objInputTS.ReadLine
+    strLineIn = objInputTS.ReadLine
+    strFileHeader = strFileHeader & vbNewLine & strLineIn
+    varInput = Split(strLineIn, ",")
+    If varInput(5) = "PTANK" Then
+        intTPedalIdx = 7
+        intINJIdx = 12
+    Else
+        intTPedalIdx = 6
+        intINJIdx = 11
+    End If
     intFileCount = 1
@@ -362,7 +374,7 @@
             If blnInWOT = False Then
-                If varInput(6) > 90 And ((varInput(2) < 3000 And varInput(4) = 3) Or (varInput(4) = 4 And InStr(UCase(strFileName), "DYNO") > 0)) Then
+                If varInput(intTPedalIdx) > 90 And ((varInput(2) < 3000 And varInput(4) = 3) Or (varInput(4) = 4 And InStr(UCase(strFileName), "DYNO") > 0)) Then
                     blnInWOT = True
                     lngLineCount = 0
                     Set objOutputTS = objFileSystem.CreateTextFile(strOutFileName, True)
@@ -370,16 +382,16 @@
                     intMaxRPM = 0
                 End If
             Else
-                If varInput(6) <= 90 Or (varInput(4) <> 3 And InStr(UCase(strFileName), "DYNO") = 0) Or (varInput(4) <> 4 And InStr(UCase(strFileName), "DYNO") > 0) Or varInput(11) = 0 Then
+                If varInput(intTPedalIdx) <= 90 Or (varInput(4) <> 3 And InStr(UCase(strFileName), "DYNO") = 0) Or (varInput(4) <> 4 And InStr(UCase(strFileName), "DYNO") > 0) Or varInput(intINJIdx) = 0 Then
                     If intMaxRPM = 0 And intExtraRows = 0 Then intMaxRPM = varInput(2)
-                    If intExtraRows < 100 And Not objInputTS.AtEndOfStream Then
+                    If intExtraRows < 50 And Not objInputTS.AtEndOfStream Then
                         intExtraRows = intExtraRows + 1
                     Else
                         intExtraRows = 0
                         blnInWOT = False
                         objOutputTS.Close
-                        If lngLineCount < 100 Then
+                        If lngLineCount < 100 And MsgBox("Run # " & intFileCount & " has " & lngLineCount & " samples. Do you you want to keep this run?", vbYesNo) = vbNo Then
                             Kill (strOutFileName)
                             intFileCount = intFileCount - 1
                         Else
@@ -924,6 +936,7 @@
                     Exit Sub
                 End If
+                If wksImport.Range("F4") = "PTANK" Then wksImport.Range("F:F").EntireColumn.Delete
                 If wksImport.Range("Q4") = "ECT2" Then wksImport.Range("Q:Q").EntireColumn.Delete
                 wksImport.Range("AL1:AZ1").EntireColumn.Delete
Old May 1, 2014 | 05:35 PM
  #149
ruff1017's Avatar
Code:
@@ -297,6 +297,8 @@
+        intTPedalIdx = 7
+        intINJIdx = 12
+    Else
+        intTPedalIdx = 6
+        intINJIdx = 11
+    End If
     intFileCount = 1
@@ -362,7 +374,7 @@
                     blnInWOT = True
                     lngLineCount = 0
                     intMaxRPM = 0
                 End If
             Else
                     Else
                         intExtraRows = 0
                         blnInWOT = False
                         objOutputTS.Close
                         Else
@@ -924,6 +936,7 @@
                     Exit Sub
                 End If
Wow! Now everything is working!
Thank you so much.
I really apreciate for doing this.
It's going to be a really good tool to use when tuning,
Cheers
Mike.
Old Feb 19, 2015 | 10:36 AM
  #150
Habitforming's Avatar
Is there any hope of adding the ability to use AEM datalogs in this software?
I don't have time to read the whole thread, but I saw no mention of it in the initial post, so I'm guessing no
