Stock rev limiter
Originally Posted by gernby,Aug 4 2010, 10:55 PM
It's the combination of it climbing slower and dropping faster that makes the rev limitter more rapid.
depending on the level of part throttle we are talking about, the climb rate is more subjective - it can be much slower than at WOT throttle or also most the same...
Originally Posted by thesilverbullet,Aug 4 2010, 10:36 PM
a slower climb will not make it to the limiter as fast, thus increasing the delay between fuel cuts. so i dont' understand how that can make anything faster?
Originally Posted by INTJ,Aug 2 2010, 11:55 PM
So the buffer is to 8,500 and two of you are hitting 8,700?
here's the latest results
first cut was at 8455 (in 4th gear)
2nd @ 8600
3rd @ 8561
4th @ 8551
5th @ 8600
6th @ 8542
7th @ 8522
8th @ 8600
The higher recovery point was not to soften the rev limiter. I just didn't want to pay any unnecesary penalty for riding the rev limiter at an autocross. If I'm going to ride the rev limitter, I want it to stay as close to 8500 as I can keep it.
I finally got my setup and was looking at the tables. Gernby, My Hondata stock setting put rev limiter at 8200 for the AP2, and Silver the VTEC window is 5900-6400. It does not appear that timing is retarded at all near the limit. Unless I'm misreading it, it is still max 40 deg advanced at the limit.
Originally Posted by gernby' timestamp='1289237676' post='19782880
You would not want to cut ignition instead of fuel, since that may fuel wash your cylinders, contaminate your oil, damage your catalytic converter, and create a lot of soot on your back bumper.
Yes back from the dead.
