TCT bolt has oil on it
Hello
Billman. I ran my engine for 5 minutes, and started to see a small amount of oil buildup on the front TCT bolt. Does this bolt leak oil? I have a 2001 with 94,000 miles. Please let me know.
FYI, I changed the VTEC solenoid gasket, that connect to the engine area. I have not changed the top gasket yet.
Thank you.
Thank you.
Scratch the post above. I reinstalled the vtec solenoid this morning. It could just be oil that slightly spilled when I pulled out the vtec solenoid. I will run my S2k again, and see if oil lands in that front TCT bolt. Thank you.
Thank you
Thank you
Update: I believe the vtec solenoid gasket changed, definitely helped with most of the leaking oil. Yes, everyday there is still a drop of oil on that front TCT bolt. I believe due to the valve cover gasket leaking. I've confirmed there is oil around the valve cover. The good news is that I have a valve adjustment appointment soon, and they will be replacing all the gaskets for the valve cover! That should stop all the small oil leaks!
Happy Thanksgiving all!!!
