trim pot/potentiometer wiring with AEM series 2
So gonna use one of these to have selectable boost...
Instructions say it needs +5v in (red), ground (black), and signal out (white). Based on pinout... I'm gonna use D connector for: +5v in @ D6, ground @D9... where should the signal go? Maybe D8- supraforums says it needs to use the correct pull up I'm confused on this one. Any help/confirmation of the above would be great- thank you! Link to supraforum info: http://www.supraforums.com/forum/sho...ition-trim-pot. Diagram here: http://aemelectronics.com/files/instructions/30-6052%20Series%202%20Plug%20&%20Play%20EMS.pdf Thanks in advance! Project's almost ready for a tune :) :) :) |
I got you ;)
