Understanding LTFT
Originally Posted by deibit,Jul 20 2010, 11:30 AM
I know the fuel trims are not really useful for tuning, but i would not call them useless for monitoring purposes, at least they are valid as "trend" indicators.
Originally Posted by urBan_dK,Jul 20 2010, 01:50 PM
Fuel trims only deal with closed loop operation (e.g. cruising). However, your long term fuel trim will apply when in open loop.
Originally Posted by spectacle,Jul 20 2010, 05:56 PM
100% not true. Open loop by definition means o2 feedback is ignored.
Btw, the emanage I have, is tuned to perform closed loop fuel control while in open loop.. but i can't monitor those trims via OBD2 (since it's using the feedback of the additional wideband installed)
I agree that LTFT is applied (not adjusted) during open loop. If it wasn't applied, then the car would run like crap at full throttle as the car gets older.
However, I really doubt the eManage runs in closed loop at full throttle. After developing my own piggy-back ECU with wideband input, I can tell you that things are changine MUCH too quickly to do real time AFR control. What I believe it does is to make small changes, monitor the results, and apply changes for the NEXT TIME you go WOT. If it makes incrementally small changes to the fuel curve based on the previous runs, it will fine tune itself slowly over time.
According to the manual:
I guess that the one that knows exactly how it works is Giles.. (and I don't think he will give that many details for obvious reasons..)
The unit provided can perform closed loop fuel control even when the stock unit is in open loop, thus the ideal air fuel ratio can be found and maintained producing the most powerful mixture at every engine speed. Using the same system much lean mixtures can be targeted while cruising to produce better than stock fuel economy. During regular operation the unit will learn the amount of adjustment needed from the underlying fuel map and store that value for use during the same driving cycle.
Note: Once the engine is turned off the adjustment values are cleared, reverting back to the internal map values.
The stock ECU doesn't store STFT at all. It only stores a running average of it that is not based on RPM at all (LTFT). When the factory ECU is in closed loop, it tries to maintain stoich in REAL TIME by agressively adjusting fuel on the fly.
A piggy back like the one I built and the eManage will not try to do this. It will monitor the O2, see that it is rich or lean, then make an adjustement to an array of "fuel trims" (ie. maybe 100 fuel trims values stored in memory by RPM index). The next time the engine hits that RPM at full throttle, it will adjust fuel by the amount it stored in memory from the last pull, then monitor the O2 again to see how close it got. It will then calculate another adjustment to use the next time, and store it in memory again. The disappointing thing is that according to your quote from the manual, the eManage erases that data every time you turn the car off. My piggy back did NOT do this, so it maintained its tune over time. That's disappointing ...
Originally Posted by urBan_dK,Jul 20 2010, 09:05 PM
You are incorrect. LTFT is applied during open loop. Watch the output on an OBDII data logger.
Realize this: partial throttle is harder to tune because of the variables involved. WOT is easy in comparison because its a linear transition through the RPM's and it is operation is not concerned with fuel economy.
Originally Posted by spectacle,Jul 21 2010, 11:15 AM
The OBD2 logger shows the trim from the ECU because it is a stored value. It is not being applied I can assure you. If it was, piggybacks like the VAFC2 would be useless.
So explain this: how does my 400whp car run the same AFR everytime I go WOT with closed loop turned completely off? No short or long term fuel trims measured or applied.
As to your second paragraph, I don't know anything about your engine management setup and can't draw any conclusions.
I fail to see how your last paragraph relates to the discussion at all.
If LTFT wasn't applied during open loop, then there wouldn't be so many people complaining about how the ECU slowly learned to compensate for their VAFC.
One of the big purposes of LTFT is to compensate for slow changes in the way the engine runs (clogging fuel injectors, dirty air filters, etc.). If the engine always runs rich due to poor air flow, or always run lean due to clogged injectors, then the LTFT should be applied during WOT to prevent it from running too lean or too rich.
