Valve timing?
Old Jul 10, 2014 | 03:51 AM
subwayasian's Avatar
Default Valve timing?
My 2006 s2k is in need of a valve adjustment every 6 months, around 6 thousand miles of driving.
My question to anyone here is, could it be possible the previous owner of the car somehow tuned it to a certain spec using AEM, or Hondata? that causes the valve timing to be messed up every 10kish miles?
Can someone mess with the valve timing with the stock ecu?
Some of my friends think that it could be a bent valve, or something with one of the belts/chains.
Any kind of input or help will be greatly appreciated. Throw out some ideas maybe.
Thanks guys =]
Old Jul 10, 2014 | 05:16 AM
Ryuu's Avatar
wow.. that's a bit much.. I check mine at 15k.. if any needed adjusting..
How many miles are on this engine..??
there is a great DIY on Valve Adjustment... https://www.s2ki.com/s2000/topic/245..._hl__diy+valve
timing gear worn..
hmmm cam lobes worn...
detailed photo's...
Old Jul 10, 2014 | 07:20 AM
96-EJ6's Avatar
The ecu has absolutely no control over valve timing on these engines.
If your having to adjust valves that often you definitely have some sort of mechanical issue.
Old Jul 13, 2014 | 12:57 AM
I see......
And I know how to do valve adjustments for the s2k.
hrm..........
Old Jul 13, 2014 | 04:41 PM
starchland's Avatar
How much are they off and are they loose/tight?
Old Jul 13, 2014 | 04:50 PM
From what I remember they are tight.
Old Jul 13, 2014 | 10:21 PM
s2000Junky's Avatar
Billman did a thread related specific to 06+ dbw valve adjustment recommendations. For what ever reason these car had a comon issue with over tight valves and needed to be checked much sooner then the previous Gen recommendation interval. I don't believe there was anything related to such the short readjust intervals you are experiencing though. But id do a search on the thread to find out for sure what was discussed. I don't have a dbw car so it meant little to me to dive in any further on the matter.
Good luck.
Old Jul 13, 2014 | 10:22 PM
s2000Junky's Avatar
And yes, valves get tight on this car as they wear. Not lose. Its the design of the motor.
klapamos
Oct 17, 2016 06:40 PM
ap1son
33
Apr 14, 2010 02:24 PM
REVZ TO9
Jul 24, 2006 12:27 PM
stefluva
Sep 7, 2004 08:54 PM
BlueS2000Boy
Jul 31, 2004 11:59 PM
