**Comptech Not Boosting** Help
Old May 1, 2008 | 02:50 PM
AusS2000's Avatar
Bondo - you posted at 7:45. By 7:48 you had bumped twice!
I think your first problem is patience.
Old May 1, 2008 | 02:53 PM
AusS2000's Avatar
In answer to your problem, if you have pressure in the crank case it's probably the PCV valve. Remove it and do the blow test. You should be able to blow from the crank case to the manifold, but not back the other way.
If it passes the blow test then you have more serious issues like blow by. Do a compression and leakdown test. If the results ain't good get your cheque book out.
Old May 1, 2008 | 07:00 PM
BondoBuilder's Avatar
Patience, huh?
Recall you made a post in my previous thread:
https://www.s2ki.com/forums/index.php?showtopic=588854
Well come to find out it's not the MAP; I put a new one on there, and there was no change.
And the reason for the bumps- being an old thread, it was immediately dropped to the second page, so I bumped it to get first page attention. Sorry.
I'll check the PCV. Thanks.
Old May 1, 2008 | 07:09 PM
AusS2000's Avatar
I didn't recommend a new OEM MAP. I recommended a higher range one, and I still do.
jabbarahm
Nov 15, 2010 07:48 AM
crav3s2k
Jan 3, 2009 10:36 AM
m00s3
Jul 25, 2005 04:16 AM
scs2000
Nov 12, 2002 03:10 AM
liquid215
Aug 29, 2002 05:40 PM
