S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   06+ Tuning Options (https://www.s2ki.com/forums/s2000-forced-induction-142/06-tuning-options-546481/)
M.A.R.C. Nov 28, 2007 05:33 PM
06+ Tuning Options
Are there any readily available/plug and play options for 06+ DBW s2000's?
Elroy Nov 28, 2007 05:58 PM
One day!
http://www.aempower.com/ViewCategory...CategoryID=116
J
M.A.R.C. Nov 28, 2007 06:08 PM
i read a little about that. seems to be like an emanage. i was thinking more along the lines of standalones.
yosephs2k Nov 29, 2007 01:12 AM
http://www.boomslang.us/ultimate.htm
they have harnesses for the emanage ultimate and VAFC
does that solve all our 06 problems?
can we supercharge/turbo our cars with only the apexi vafc? no fmu or fuel pump?
M.A.R.C. Nov 29, 2007 03:43 AM
afc's don't do anything for timing adjustments. fmu's just increase fuel pressure as boost increases and i really don't like them. depending on the setup a fuel pump would be either necessary or at a minimum a good investment.
HvRRZ Nov 29, 2007 05:50 AM
motec.
otherwise you need to get a special harness for the ems, but will loose certain features(i forget which ones). same goes for emanage.
2big4aS2000 Nov 29, 2007 06:10 AM
with -06+ they changed to using cam & crank sesors like the rsx and use a returnless fuel system like a rsx, the fuel pressure regulator is in the tank.
M.A.R.C. Nov 29, 2007 09:26 AM
yeah i'm sure it's a little more complicated but i'm sure someone has or will figure something out. just trying to see what people are using or what's on the horizon.
DYNOMIKE@AUTOWAVE Nov 29, 2007 04:22 PM
pm me I have a solution for your 06-07 standalone needs
2QYK4U Nov 29, 2007 04:57 PM
Search feature is your friend. There are way too many of these type of threads. http://i21.photobucket.com/albums/b2...usa_snooty.gif
© 2026 MH Sub I, LLC dba Internet Brands
