06+ Tuning Options
Old Nov 28, 2007 | 05:33 PM
M.A.R.C.'s Avatar
Default 06+ Tuning Options
Are there any readily available/plug and play options for 06+ DBW s2000's?
Old Nov 28, 2007 | 05:58 PM
Elroy's Avatar
One day!
http://www.aempower.com/ViewCategory...CategoryID=116
J
Old Nov 28, 2007 | 06:08 PM
M.A.R.C.'s Avatar
i read a little about that. seems to be like an emanage. i was thinking more along the lines of standalones.
Old Nov 29, 2007 | 01:12 AM
yosephs2k's Avatar
http://www.boomslang.us/ultimate.htm
they have harnesses for the emanage ultimate and VAFC
does that solve all our 06 problems?
can we supercharge/turbo our cars with only the apexi vafc? no fmu or fuel pump?
Old Nov 29, 2007 | 03:43 AM
M.A.R.C.'s Avatar
afc's don't do anything for timing adjustments. fmu's just increase fuel pressure as boost increases and i really don't like them. depending on the setup a fuel pump would be either necessary or at a minimum a good investment.
Old Nov 29, 2007 | 05:50 AM
HvRRZ's Avatar
motec.
otherwise you need to get a special harness for the ems, but will loose certain features(i forget which ones). same goes for emanage.
Old Nov 29, 2007 | 06:10 AM
2big4aS2000's Avatar
with -06+ they changed to using cam & crank sesors like the rsx and use a returnless fuel system like a rsx, the fuel pressure regulator is in the tank.
Old Nov 29, 2007 | 09:26 AM
M.A.R.C.'s Avatar
yeah i'm sure it's a little more complicated but i'm sure someone has or will figure something out. just trying to see what people are using or what's on the horizon.
Old Nov 29, 2007 | 04:22 PM
DYNOMIKE@AUTOWAVE's Avatar
pm me I have a solution for your 06-07 standalone needs
Old Nov 29, 2007 | 04:57 PM
2QYK4U's Avatar
Search feature is your friend. There are way too many of these type of threads.
