1/4 mile times with FI
Old Sep 8, 2005 | 12:21 PM
japwhiz's Avatar
Default 1/4 mile times with FI
Curious to see what people are running in the 1/4 with FI. I know these are not 1/4 mile cars but I am still curious to see what times have been run. If you could list your mod
Old Sep 8, 2005 | 04:49 PM
JDMKID35's Avatar
Banned
S2000's are perfect for 1/4 mile!!! if you do it the right way
Old Sep 8, 2005 | 04:52 PM
AusS2000's Avatar
I think the record is about 11.5. But that's a fairly serious set up.
Old Sep 8, 2005 | 05:24 PM
JDMKID35's Avatar
Banned
I think I have the rec for best MPH@ 134..that was on low boost.. might get back to the track this season.. but if not look for me at the star of next season all the bugs will be worked out and should have the rec for most HP
Old Sep 8, 2005 | 05:50 PM
honda9krpm's Avatar
interestingly both the trap time and trap speed records were done on stock gearbox and diff.
Hat off to you guys.
Old Sep 8, 2005 | 06:40 PM
BlueMonde's Avatar
113 @ 106mph his s/c is TeamSiRs2k metro ny,
the weather didnt help that day i think the temp was over 100
here's the vid
click click
Old Sep 8, 2005 | 07:06 PM
honda9krpm's Avatar
here's the vid
click click
bluemonde, that video showed 13.3@106
I've done 12.9@119mph. I am still trying to improve my 60" time.
My setup still bog at 7500 rpm launch. I will have to launch at 9000rpm next time.
Old Sep 9, 2005 | 07:29 AM
flexer's Avatar
Hey,
I am at altitude and have run a 13.3 with 10 pounds of boost. Everyone tells me its good for a mid 12 if I go down to sea-level. Set-up is a lovefab kit. To give people a idea of what altitude does. I raced a buddy in his 95 Viper. We are neck and neck until about 100 then he starts to SLOWLY walk away. He ran that viper for a 12.4 pass at sea-level. Just gives you a idea. The S2k is a VERY POTENTIAL car.
J. R.
Old Sep 9, 2005 | 08:44 AM
Halo's Avatar
So, it's just a myth that turbos aren't as affected by alititude given that they produce a set amount of boost even if atm pressure is lower than sea level?
Old Sep 9, 2005 | 11:31 AM
blues2k3's Avatar
12.0 @119 and 11.9 @120, under 7psi/ nitto drag radials/ 1.80 60ft. That was with a stock block, it's not stock anymore....
