1052 software help
Old Apr 2, 2010 | 05:22 PM
Revenge's Avatar
Default 1052 software help
Can someone provide a link to where I could get the latest version of the AEM 1052 software for XP. What is the latest version. I went to the AEM site but I am unsure which is the right one.
Thanks in advance.
Old Apr 3, 2010 | 06:00 AM
camuman's Avatar
aempro software v1.0 is what i use, and it works just fine
Old Apr 3, 2010 | 08:32 AM
joes sled 2000's Avatar
I think that the last version for the older boxes was V 1.21 . As i understand that version was no better than v 1.19 . I run v 1.19 and it is excellent !
Old Apr 3, 2010 | 08:36 AM
camuman's Avatar
That's the firmware on the box. I run 1.19 it's fine. Read on the forum if it's even nec to upgrade
Old Apr 3, 2010 | 09:17 AM
D1sclaimer's Avatar
It says to just keep 1.19 since the 1.21 was for a certain AEM box only.
http://forum.aempower.com/forum/inde...c,21840.0.html
Heres a link for the latest AEMPro.
http://forum.aempower.com/downloads/...ease070406.EXE
Old Apr 3, 2010 | 04:46 PM
Blucky87's Avatar
you can use the newer AEMTuner program with the older boxes also.. i prefer AEMTuner because it looks alot better and seems easier to use than Pro. They also stopped updated Pro some time ago, I suggest giving it a try!
Old Apr 4, 2010 | 04:37 PM
D1sclaimer's Avatar
I thought there were variances with AEMTuner and the series 1 boxes? Can you confirm that everything stays the same.
I loaded one of my tunes up with AEMTuner before from AEMPro and the VE tables were slightly changed so I just didn't mess with it and stayed with AEMPro.
Old Apr 4, 2010 | 08:10 PM
jonbar87's Avatar
You can use Tuner on a series 1 unit. The only difference is, the wizards in tuner don't work with 1.19 maps so just create a map in pro with all the appropriate wizards selected, save it as a v1.19 file, then open it up in Tuner. Also, the fuel trim "Fuel vs. Idle RPM" table will say "This table is not available in current calibration." This is because in AEMPro it's called "Fuel Offset vs RPM" but in Tuner it's referenced as "Fuel vs. Idle RPM." This issue has been addressed here on the AEM Forum as they are *supposed* to be making Tuner completely compatible with series 1 units. Tuner's GUI is much better than Pro, I would recommend using it over Pro.
Old Apr 5, 2010 | 08:32 AM
Revenge's Avatar
I thoght I was suppose to get like version 3.23? I have the AEM v1 box?
Old Apr 5, 2010 | 10:32 AM
Revenge's Avatar
OK it was the right version thanks guys!! I need to lear how to work it now!
