-10AN T fitting?
Anyone know where I can find a T fitting in -10AN size. I want to put in the bottom of the car on the Fuel Feed line so I can open it to drain the FUEL out when switching between pump and E85. My fuel feed line is -10AN.
Push-on fittings with push-on hoses work just fine. I prefer the XRP push-on hose over the Earl pieces and over any other braided setup. The XRP hoses are extremely durable and will not reek of fuel smell (unlike other push-on hoses). With the ease of use, there really is no negative.
One caveat, if you plan to run fuel lines on the undercarriage, braided hoses may suit you better due to the extra aluminum sheath. I'm not sure how well rubber push-on hoses will last from debris constantly hitting the lines.
In addition, XRP push-on hoses have a larger inner diameter for the same AN size hose, in comparison to the braided equivalent. Example a 10AN XRP push-on hose has ID of 0.625", the braided hose (Perform-o-flex) ID is .5625" That's 11% larger in diameter!
