2.5L Stroker
I have the 2.5L stroker by inline pro. Is it possible/recommended to put a turbo or supercharger on it? Thanks,
I'm sure it's possible, and recommended is kind of subjective. I doubt you would have problems if it was tuned right and as long as you keep the revs limited to low enough that the piston speeds aren't drastically increased over stock (would still work, just will increase the likelihood of a failure). I'm not a pro by any means, but that seems to be the general consensus I've seen while reading through here over the time I've been a member.
what CR is that motor? 11:1 boost it either way up to around 11-15psi. 9-10.5:1 MORE BOOST then that lol :) 13:1 ehh, idk def not pump lol but e85 or race gas i suppose.
either way, BOOST IT. what power do you make now and how much do you want ultimately? |
Originally Posted by camuman
(Post 20436451)
Originally Posted by dieseldare02
(Post 20436729)
either way, BOOST IT. what power do you make now and how much do you want ultimately? if you want more tq, turbo ELTM mani, divided, gt35/6262/sw363 sized turbo and go for 500 pump. |
