200hp@3000rpm
Old Aug 2, 2010 | 04:05 AM
SRap1's Avatar
Default 200hp@3000rpm
Has anyone been able to obtain 200whp at or before 3000rpm? If so can you post dyno sheets and your setup please
Old Aug 2, 2010 | 05:27 AM
camuman's Avatar
the only way your gonna do it is with nitrous sprayed at 3k rpm or sooner.
IT AINT GONNNA HAPPEN. i hit it at around 4600rpm. i have seen some gt30 ELTM cars hit it anywhere from 4100-4600 rpm. greddy cars too.
3k is impossible.
at 3k rpm i am at 112ishwhp and i see 4-5psi down there.
Old Aug 2, 2010 | 06:28 AM
ChefJ's Avatar
you didn't say in an s2k. So I could probably ramble off hundreds of cars that can hit 200whp at 3k rpms's. Most would be of the high compression v8 - v12 style. I think the supra can hit it there aswell.
Old Aug 2, 2010 | 06:52 AM
SRap1's Avatar
[QUOTE=ChefJ,Aug 2 2010, 06:28 AM] you didn't say in an s2k.
Old Aug 2, 2010 | 07:03 AM
camuman's Avatar
assuming my math is right, you would have to make 350wtq at 3k rpm. you have a better chance of finding a pot of gold at the end of a rainbow.
Old Aug 2, 2010 | 07:35 AM
305s2k's Avatar
How about a:
GT28RS with a 0.82 A/R T3 divided housing on a good divided manifold (Pfab, Full Race, AFI)???
That might spool fast enough to do it. It be cool to try it out. Expensive experiment though lol.
Old Aug 2, 2010 | 07:36 AM
SRap1's Avatar
so as of right now 4000 is the lowest rpm with 200whp? can you post the setup
Old Aug 2, 2010 | 08:27 AM
camuman's Avatar
https://www.s2ki.com/forums/index.php?showt...&#entry16423339
graph was in mph, but thats 4th gear, so i think you can guess about what is what. id have to look at mine to put 2 and 2 together mph to rpm. anywho, thats a healthy greddy kit dyno, and they make the most tq down low.
Old Aug 2, 2010 | 08:45 AM
ChefJ's Avatar
just remember that the lower gears aren't going to make power as early in the power band. You may be able to make 200 at 4k in 4th but you won't get there in 3rd 2nd or 1st.
Old Aug 2, 2010 | 08:49 AM
secondhandloser's Avatar
pretty unlikely to have happen....
