2jz S2000 *UPDATE*
Old Feb 5, 2007 | 06:40 AM
  #111
PRS2K's Avatar
I Drove the car for the first time Saturday. Everything seems well we are working on getting full control of the s2000 digital dash. We are having trouble with getting the speed to read. We thought it would be an easy wiring job because the schematics for the speed sensor on the v160 are very similar to the speed sensor on the F20c Trans. However what seems easy at first turns into a headache very fast.
Old Feb 6, 2007 | 06:53 AM
  #112
PRS2K's Avatar
Here is a small update.
The power steering is now functional. Many do not know the S2000 is one of the only cars along with the NSX that use a Fully Electronic power steering rack. This rack has no fluid inside and is ran with a micro processor. Inputs from the steering sensor are digested by a microprocessor control unit that also monitors input from the vehicle's speed sensor. The sensor inputs are then compared to determine how much power assist is required according to a preprogrammed "force map" in the control unit's memory. The control unit then sends out the appropriate command to the "power unit" which then supplies the electric motor with current. The motor pushes the rack to the right or left depending on which way the voltage flows (reversing the current reverses the direction the motor spins). Increasing the current to the motor increases the amount of power assist.
The vehicle is now controlled an functional through 2 ECU
Old Feb 6, 2007 | 05:10 PM
  #113
gerdaland's Avatar
learn something new about my car everyday.
Old Feb 6, 2007 | 05:50 PM
  #114
Planets's Avatar
[QUOTE=PRS2K,Feb 6 2007, 07:53 AM] The vehicle is now controlled an functional through 2 ECU
Old Feb 7, 2007 | 03:19 PM
  #115
timg's Avatar
[QUOTE=PRS2K,Feb 6 2007, 08:53 AM] Here is a small update.
Old Feb 7, 2007 | 03:35 PM
  #116
Aze85's Avatar
interesting stuff.
Old Feb 8, 2007 | 05:02 AM
  #117
PRS2K's Avatar
Originally Posted by timg,Feb 7 2007, 04:19 PM
Couldn't one AEM EMS be programmed to handle all of that? The only complex thing the stock S2000 ECU does is control the engine. Everything else is very simple which is why I think the Supra EMS could be used to do it all. Am I missing something?
Otherwise I like the whole project!
Tim
To a certain extent yes. However with out the availability of the stock Ecu the car would not run self diagnosis on parts such as the power steering rack. The supra EMS would have been able to control the 2jz motor. However there are S2000 components that can and will only be controlled by the stock Ecu and/or S2000 EMS. Temp, EPS being two of them.
Old Feb 8, 2007 | 09:47 AM
  #118
OverBooster's Avatar
Gawd, could this be the coolest Frankenstein ever? Survey says...YES!! Mad props to you and all the time you have no doubt spent on this. It would be safe to call you a visionary for accomplishing this. So uh, where are the vids?
Old Feb 8, 2007 | 05:09 PM
  #119
timg's Avatar
Good stuff. Thanks for the explanation. I wonder if the AEM S2000 EMS really does anything with the EPS...
Tim
Old Feb 9, 2007 | 06:14 AM
  #120
VeilsideAP1's Avatar
Glad to see a proper reinforcement was installed rather than a modded STB.
