3.5 Bar Map Sensor vs. Stock
Old Jul 3, 2006 | 06:40 AM
C45P312's Avatar
Default 3.5 Bar Map Sensor vs. Stock
Tuners:
Would it be easier to tune if I kept the stock map sensor versus replacing it with a 3.5 bar map sensor? I will only be running 9psi of boost. When I do plan to boost more, I ofcourse will def replace it but for the time being, will the stock on suffice @ 9lbs?
Thanks
-Carlo
Old Jul 3, 2006 | 06:51 AM
xviper's Avatar
Not an expert on this, but I thought that when you boost, you use some sort of MAP "clamp" to hide boost (MAP signal) from the ECU anyway, so does it matter as long as the ECU gets the proper signal when not in boost?
Old Jul 3, 2006 | 07:16 AM
C45P312's Avatar
With my limited knowledge, I see only 3 ways to deal with boost and map sensors.
1) clamp it
2) trick it
3) alter it
I would assume that an AEM EMS or any other stand alone would alter it.
Old Jul 3, 2006 | 07:21 AM
Sideways's Avatar
Since your factory ECU is set for the factory MAP sensor it would not work with the aftermarket sensor so stick with the factory MAP sensor until you get an AEM.
The voltages are different and the AEM allows you to enter the different ranges.
Old Jul 3, 2006 | 02:28 PM
AusS2000's Avatar
The only reason to go to a 3.5 bar MAP sensor is if you are boosting more than 1 bar and if that is the case you should definitely be using an AEM EMS or similar.
If you're using the AEM then it's simple a matter of telling it what MAP sensor you're using and it will calibrate itself accordingly.
Old Jul 3, 2006 | 03:13 PM
cpoz's Avatar
As stated above, if your running your factory ECU, your going to hide the boost from it. If your using an AEM EMS, then rock the 3.5 bar. It is easy to setup.
FYI: The factory MAP is good to about 11 psi
Old Jul 3, 2006 | 03:35 PM
AusS2000's Avatar
Why? I'm not 'rock'ing it and yet I am turbocharged and using the AEM EMS.
Old Jul 3, 2006 | 03:39 PM
ex-eclipse's Avatar
How much boost?
Old Jul 3, 2006 | 03:48 PM
AusS2000's Avatar
8.5psi. That's why I haven't seen a need to upgrade the MAP sensor.
I would say that the only reason to upgrade the MAP sensor is if you are going higher than 10 or so psi at which point you should already have proper engine management and possibly a built engine.
Old Jul 3, 2006 | 04:16 PM
cpoz's Avatar
AusS2000 I was referring to his original quote:
When I do plan to boost more, I of course will def replace it
Like I said, The stock one is good up to 11.
