3" Dual exhaust system UPDATE Dyno Graph
Asura,
again, not to change your design, but I've been looking for an exhaust setup even more subtle. Is this muffler possible if I order the exhaust?
Vibrant Performance
Vibrant Performance
Originally Posted by Asura,Jan 22 2008, 03:01 PM
This was tested on a Dynapack 4000. Shawn Church's dyno is the standard that most people use in SoCal.
We have no plans to re-dyno the system on a different dyno without a testpipe.
-Asura
-Asura
Since there have been so many requests, I will look into it. However, you should note the HP gains and fitment may not be anywhere near the design of the intended product if you plan to make modifications
-Asura
-Asura
-Asura
-Asura
The prototype is not on any car at this time. I will try to swing by a meet once I get back. You will see this system on Sideways' and Casterdog's car (among others) very soon.
Add me to the list as well. I am interested with it exactly as is now.
However, if you are able to retain the good qualities of the current design with the 04+ style tips, I could be interested in that too.
Can you also provide an extra 3 bolt flange? My entire system is setup with V-bands right now and I would rather modify my current downpipe/cat/testpipe system than your exhaust. My stock cat still has the normal 3 bolt flange in the stock position, but with a 3 bolt to v-band adapter to my exhaust (if I unbolt the adapter, my cat will bolt straight to your exhaust). That means with your exhaust I would just need one spare 3 bolt flange to redo my test pipe with. I would likely also still need to redo the downpipe a bit. I am definitely still interested.
Thanks.
Tim
Thanks.
Tim
