382 hp on 10 psi of boost
My setup is an '05 with a KraftWerks high boost kit (10 psi) with stock header, cat, and exhaust.
In addition to the KW SC kit, I supplied: RC 650 cc injectors w/plug and play clips - about $450 Walbro fuel pump - about $100 Hondata K-pro ECU - $1800 Hondata intake gasket - $60 Valve cover, sensors, etc. for K-pro conversion - about $300 ACT HD pressure plate - about $525 Stock disk - about $120 Stock release bearing _ about $125 Spark plugs, oil filter, Mobile 1 oil - about $60 Tuning - $350 Sub Total $3885 Kit $5495 Grand total $9380 I removed the engine because I was replacing the clutch and had initially intended to install a thicker head gasket. Lowering the compression is not necessary or advisable. The supercharger install was done after the engine was re-installed. Removing the engine is not required. Protecting the paint http://i236.photobucket.com/albums/f...t/P3300059.jpg Driveline removed http://i236.photobucket.com/albums/f...ct/ontable.jpg Owner supplied parts (Injectors and K-pro not received yet) http://i236.photobucket.com/albums/f...t/P3310066.jpg Kit parts http://i236.photobucket.com/albums/f...ect/Thekit.jpg Sensor install http://i236.photobucket.com/albums/f...t/P4010065.jpg Clutch http://i236.photobucket.com/albums/f...t/P4020061.jpg Intake gasket http://i236.photobucket.com/albums/f...datagasket.jpg FMIC install http://i236.photobucket.com/albums/f...t/P4110083.jpg Hondata K-pro install http://i236.photobucket.com/albums/f...t/P4080064.jpg Pictures of engine bay coming (forgot where I put them :) ) Scan of original printout from last dyno test http://i236.photobucket.com/albums/f...June252008.jpg Overlay of KraftWerks kit results on my previous Comptech vs Stock results http://i236.photobucket.com/albums/f...kctkwcombo.jpg Taking down $60k+ cars at the track, priceless...not really just the price of an S2 plus $9380, but the feeling IS priceless. |
Did Ed do the tuning at Balanced?
What was the installed price? Those numbers look like parts only?
He did all the install himself. So no labor other than tuning.
How are your IAT in different conditions? Track, cruising, bumper to bumper traffic.
simply awesome! Kudos to you MrHonda! :thumbup:
Sick, power is so linear, no spikes at vtec at all. That graph is fun to look at better if it made 400 :D it's close
how does it feel compare to the old comptech? Better yet a turbo car? I might have to get rid of the snail.
