4" ASP Racing pulley on Vortech only making 8lbs of boost?
Old Dec 16, 2011 | 07:52 AM
Wydget's Avatar
Default 4" ASP Racing pulley on Vortech only making 8lbs of boost?
Anyone know why this would happen? I'm at the dyno right now and it's only reading 8lbs of boost. It's a vortech V2 blower, freshly rebuilt from vortech. Any help is appreciated...
Old Dec 16, 2011 | 07:58 AM
Sideways's Avatar
Boost leaks and improper tenision of the belt are the first things to rule out. How many rpm are you reaching?
Old Dec 16, 2011 | 08:03 AM
Moddiction's Avatar
Former Sponsor
Don't have a front mount do you? If not then either belt slip or boost leak. I am running a 4" ASP pulley on my AP1. I have hit as high as 13 psi with it on a cold day.
Old Dec 16, 2011 | 08:05 AM
Wydget's Avatar
We are only going to 8600 rpm. The number 4 coil pack is going out right now. It just raised to 10psi.
Old Dec 16, 2011 | 08:09 AM
Sideways's Avatar
The boost will rise with the rpms, 8600 rpm is a little low. Run it up and see what it puts out.
Old Dec 16, 2011 | 11:24 AM
Wydget's Avatar
So the number 4 coil keeps going out. It gets really hot and starts misfiring. Once it cools down its fine. Any ideas on whats going on???
Old Dec 16, 2011 | 01:07 PM
bruthaboost's Avatar
Check your belt tension. If you are using a fresh new belt and have not retightened, I am certain it has stretched and you have lost some tension/traction. I have some spare coils if you need to borrow them.
Old Dec 16, 2011 | 01:39 PM
Wydget's Avatar
It is misfiring badly. It fixes it when I switch out the coil but it goes bad after a few minutes.
Old Dec 16, 2011 | 02:05 PM
So I'm understanding you correctly; your ignition system will start misfiring after putting in a known good coil? If so, check your wiring and connectors. I don't have my helms in front of me to look at the circuit diagram. It's at a friends and I'll have a look at it tomorrow and see if anything jumps out.
Old Dec 16, 2011 | 02:55 PM
Wydget's Avatar
Yes, we switched out three coils on it so far. They are used coils but were in good working order prior to installation in my car. My S sounds like a wrx but smooths out as I accelerate.
