is 4 bars on temperature gauge safe?
Old Jan 19, 2007 | 06:29 AM
danw's Avatar
Default is 4 bars on temperature gauge safe?
I am running the vortech blower on stock boost with AEM ECU. I got the modifry AEM temperature gauge fixer installed and they calibrated it to the same as stock. I went out for a little burn and revved the car up around 6-7000RPM for a few minutes hard driving and the temperature gauge went up to 4bars. I have never seen it go above 3 even on track days when the car was stock, I read somewhere it should never go above 3 bars.
I did not drive it hard for long and its very cold here in UK right now. I knew it was going to run hotter but should I be concerned? I have a track day tommorrow.
Is it ok to run at 4 bars hot? what if it goes to 5 is it time to stop?
The car is running fine with enough oil, coolant etc.
Old Jan 19, 2007 | 06:34 AM
QUICK_AG's Avatar
Mine did this quite consistently when sitting at lights for more than a few seconds or on really warm days in heavy traffic. I called the guy at modifry and was assured this is normal (suppose to be more accurate/sensitive than the honda stock one), I have never had it go past four bars or overheat. I hope this helps
Old Jan 19, 2007 | 06:36 AM
danw's Avatar
Ahh ok actually it wasn't till I slowed down and was stuck in traffic I saw it had gone to 4 bars
Old Jan 19, 2007 | 06:57 AM
inlinepro1's Avatar
4 is normal, ive even hit 5 once or twice.
Old Jan 19, 2007 | 09:33 AM
hboy7777's Avatar
i think i recall 4 bars was around 235 degrees which is getting kinda hot, 5 bars is not normal-have your car checked out.i run 500+hp and never see above 210-215 on the hardest of runs and almost 4 hours on the dyno. stock radiator, tstat, fan switch
Old Jan 19, 2007 | 09:54 AM
inlinepro1's Avatar
i dont know it might have been 5 maybe 4 who knows, ive only hit it once or twice and i drive thec ar pretty damn hard
Old Jan 19, 2007 | 10:28 AM
pushin9's Avatar
Stock display 3 bars = 235
Modifry display 6 bars = 235
Old Jan 19, 2007 | 10:43 AM
inlinepro1's Avatar
hah, so im assuming 5 bars is somewhat ok? in that case i probebly have hit 5 bars
Old Jan 19, 2007 | 10:57 AM
kingvictor's Avatar
I think that is normal. I get 5 when sitting in heavy traffic. (With modifry ect)
Old Jan 19, 2007 | 11:03 AM
pushin9's Avatar
Just like the stock gauge, the Modifry version will light the 3rd bar for most normal driving conditions but you will see 4 bars if the ambient temperature is very high, you're in stop-n-go traffic, or you're on the track. That's nothing to be concerned with, you'll get used to it and may even be reassured knowing the gauge is actually giving you useable information for a change. Only very rarely will additional bars light up, and if they do you should be looking for a place to pull over and determine what the problem is.
