440cc Decision
Old Sep 13, 2005 | 06:02 PM
folex187's Avatar
Default 440cc Decision
I know a number of you guys run 440cc injectors. Who has the best price on them right now? Tech2 said around $90/piece, is that a good deal?
Another thing is, will the 440 yield the best results with tech2 7lb pulley tuned on an ultimate emanage? I did a search and read a couple posts of people having partial throttle issues.
Old Sep 13, 2005 | 06:55 PM
revhi's Avatar
<--Partial throttle issues, stock injectors. I blame it on the tuning, not the Emanage or injectors.
Old Sep 13, 2005 | 07:22 PM
Asura's Avatar
You should not need injectors. If you are getting injectors, go with 550's or 750's so you won't have to get new ones when you decide you need a 9 psi pulley.
The price is fine but they are unnecessary.
Old Sep 13, 2005 | 07:56 PM
folex187's Avatar
I kind of want to ditch the FMU and just use static fuel pressure. I thought stock injectors were at about max load with the 7lb pulley.
Old Sep 14, 2005 | 07:45 AM
Spoolin's Avatar
I have a set of RC 440cc injectors that I used for about 4000 miles and they worked great with my E-manage. I'll sell them for $200, but you will need to get some plug in harnesses. They only run about $30 for 4.
Old Sep 14, 2005 | 06:18 PM
folex187's Avatar
Spoolin- do you have the clips for them?
Old Sep 15, 2005 | 05:18 AM
Spoolin's Avatar
No spacer clips. I actually used a couple of small washers and they worked great.
Old Sep 15, 2005 | 12:44 PM
folex187's Avatar
Where do I go to get the actual clips? Are they model specific?
Old Sep 15, 2005 | 12:59 PM
Spoolin's Avatar
Are you referring to the spacers to raise the fuel rail up or the actual wire clips? If it's about the spacers to raise the fuel rail up, you should be able to get in contact with RC to get them. If you're referring to the wire clips or plug-ins, you can get some from Darryl at UR for around $20 or $30.
Old Sep 15, 2005 | 05:42 PM
folex187's Avatar
Ok on to the next question: What would be the better choice with the Ultimate Emange- Running static pressure with the Comptech FMU or to us the stock FPR?
