$45 fix for your hot Inline Pro intake
Old Oct 30, 2007 | 05:53 PM
skibum's Avatar
Default $45 fix for your hot Inline Pro intake
I recently installed my Inline Kit and have read from others on here that the filter sits so close to the turbo that it sucks in mostly hot air.
Here is my remedy:
Purchased this part from Checker Auto for $45. It's made of polished aluminum and matches the other polished pipe under the hood.
Here it is installed with the K&N filter from inline at the end.
I do not have any way of comparing the difference between the 2 filter locations so please don't ask.
Old Oct 30, 2007 | 05:57 PM
ChefJ's Avatar
nice. What are the dimensions.
Old Oct 30, 2007 | 06:10 PM
skibum's Avatar
The pipe is 3" diameter. Some sort of bracket will need to be added to prevent the tube from self destructing on the cross-member. Until I figure that out, I simply took an extra 4" of turbing (which comes with the pipe), split one side, and placed it over the edge of the beam.
Old Oct 30, 2007 | 06:31 PM
ChefJ's Avatar
how about the length and the degree of the bend?? I would love to ut something like this onto my cold side aswell but being able to find the same unit would be difficult.
Old Oct 30, 2007 | 06:38 PM
skibum's Avatar
Looks like I overpaid. Here are all the specs and ordering info.
http://www.draglinepro.com/intake-15729601...Brand-sr-1.html
Old Oct 30, 2007 | 06:46 PM
ChefJ's Avatar
Awesome. I will look into that. Much cheaper then a custom fabbed piece.
Old Oct 30, 2007 | 06:48 PM
AirborneS2K's Avatar
Looks like your hood won't close in that picture. You do have a stock hood, right? and no fitment issues?
Can I get a pic of what your fix was for the cross member-intake pipe contact?
Old Oct 30, 2007 | 06:58 PM
skibum's Avatar
Here is a pic to give you a better idea of the height - it does not hit my hood.
As for the temporary fix: I used a 4" piece of thick hose like the one you see coming out of the valve cover. I then made 1 slit down the length of the hose. I placed that slit over the vertical edge of the cross member so that the pipe rests on it.
Old Oct 30, 2007 | 08:30 PM
Spec_Ops2087's Avatar
Might have to get this and try it out
Old Oct 30, 2007 | 09:12 PM
leo520's Avatar
this might give u more HP ,since it doesn't suck all the hot airs anymore, when are u planning to get it dyno?
