60-1 OR s366 hmmm...
Old Mar 27, 2009 | 01:58 PM
justnnavy's Avatar
Default 60-1 OR s366 hmmm...
ok so i just got my lovefab gt1 kit which came with the 60-1 used. now i just happen to have a brand new borg warner t4 s366 sitting on my floor collecting dust. im trying to figure out which one i wanna use... im looking around 400hp on 93 with a high boost tune as well. currently have a stock block for now but will eventually rebuild so id like some room to upgrade... has anyone ever used the s366? i couldn't find much. let me know your thoughts!
2000 stock block, 3" exhaust, tuning with aem
thanks all!
Old Mar 28, 2009 | 12:06 AM
Spoolin's Avatar
I have the 60-1 on my lovefab gt-1 right now and just got done with a new tune. Im now putting down 580 whp and 440 lbft of tq with it but its maxed with the race fuel. Its been a great turbo for me. Ill be putting up a thread about it soon with a dyno graph.
Old Mar 28, 2009 | 12:07 AM
Spoolin's Avatar
Oh yeah, the boost im running on it is 28 psi falling to 25 psi at the top.
Old Mar 28, 2009 | 07:07 AM
s_d2k's Avatar
which turbine housing and which turbine stage 3?
Old Mar 28, 2009 | 07:26 AM
rob!'s Avatar
go with a larger turbo. nothing worse then a turbo that doesnt pull hard to redline. Also it sucks if you want more down the road and you need to upgrade rather then changing the fuel and adding more boost.
Old Mar 28, 2009 | 08:15 AM
Spoolin's Avatar
My 60-1 has the T3, .82 ar, 76 housing. And it's not that bad if a turbo doesnt pull all the way to the top. Wait until i post up my dyno graph when i make the thread. I have 525+ whp from 6000 rpm all the way to 9100 rpm.
Old Mar 28, 2009 | 08:18 AM
justnnavy's Avatar
yes very interested in your dyno.... post post post... more specs as well please =)
Old Mar 28, 2009 | 08:44 AM
ScorpionT's Avatar
Ive used the S366 and theyre a bit laggy. You could make 700+whp with one, so no sense in using it to make under 600whp. Keep the 60-1 for sure.
Old Mar 28, 2009 | 09:03 AM
s_d2k's Avatar
on the dyno u did only race gas or also pump gas?
Old Mar 28, 2009 | 09:12 AM
Revenge's Avatar
is the 60-1 close to a gt30 or gt35/
