600whp turbo
Looking to pass or crest 600. I currently have the gtx3076r on the ptuning kit. From the research I've done. Doesn't seem my current turbo would be up to the task. I know comparing it's performance from other cars isn't apples to apples. Also looked into the gtx3576r but not many are running it. I don't want to have to step up to a gtx3582 if possible. I enjoy the quick spool of gtx3076r. Are there any turbos that'll reach my goal and still spool quick? Maybe something in the Forced Performance line up?
you will need to swap out the turbo to a gtx3576r. You will also need to run e85 and you will need bigger injectors. i recommend the id 1300cc or the fic hi z 1650cc injectors. i also recommend a fuel fuel sensor. OR you can just run race gas. 1000cc injectors will make 600whp no problem with race gas. Race gas is just expensive and not practical unless you just it only for racing and not on the street.
here is my stock f20c with a gtx3576r on the track forged manifold. 450whp on 91 octane and 617whp on e85. the red line was my old 2.4 f24 stroker. The stroker makes the same about of power but spools about 500rpm faster. I wold expect you ptuning manifold to spool the same or close as my 2.4 stroker since the running on your manifold or short. The ptunning manifold should spoool 200-400rpm faster than mt track forged sidwinder manifold.
EFR turbos can only be used with a top mount or sidewinder style manifold.
The fasting spooling turbo for a 600whp goal with a ptuning manifold would be a garrett gtx3576r with a .63 tial vband hotside.
Originally Posted by Jin_SK' timestamp='1434495246' post='23650546
EFR 8374 should fit the bill, probably will have the fastest spool of any turbo at that power level
Unfortunately the EFR series won't fit with a ptuning kit. The gtx3576 is my top choice, followed by the gtx3582r. I have no problem running race gas as my car is driven maybe twice a week and not very far. Was thinking of doing the following.
GTX3576
Ported intake
Big throttle body
c16
Also looking into maybe a stroker and lower compression.
GTX3576
Ported intake
Big throttle body
c16
GTX3576
Ported intake
Big throttle body
c16
GTX3576
Ported intake
Big throttle body
c16
