850 whp Build - Quest for 9's - Completely New Setup
Old Nov 20, 2013 | 09:51 AM
hybrdthry911's Avatar
850whp would net you some deep 9's. Are you going to attempt this on the stock trans?
Old Nov 20, 2013 | 10:11 AM
1SlowSi's Avatar
Originally Posted by spectacle
Your tuner sucks.
Quite possibly one of the worst around
I am going attempt a 9.99 with the stock trans which is why I bought a spare for the attempt It has been done before at 9.95 so why not try until I can get the G-Force trans in the spring.
Old Nov 20, 2013 | 10:39 AM
Originally Posted by 1SlowSi
Originally Posted by spectacle' timestamp='1384972696' post='22886346
Your tuner sucks.
That 9.95 pass was likely mine. We had a couple trans let go in well into fourth gear at 800whp. We turned the power down to ~725whp and were able to keep one together for one glory pass lol. We had some traction issues but still cut a 1.51 sixty foot not bad for stock struts with drop springs. Your wider tires and longer gearing with the 3.9 should help you, but you will still most likely have to shift into 5th.
Old Nov 20, 2013 | 10:40 AM
GrandMasterKhan's Avatar
so much clean.
Old Nov 20, 2013 | 10:59 AM
baZurk's Avatar
That motor looks delicious.
Old Nov 20, 2013 | 11:21 AM
passmans2kny's Avatar
yes another s366 build i love it, that engine looks better than one fresh from honda, great looking start
Old Nov 20, 2013 | 11:34 AM
neeman77's Avatar
Looking great, good luck with the rest of the build!
Old Nov 20, 2013 | 11:45 AM
1SlowSi's Avatar
Your build is the one that started this mess! Your setup was super freakin clean man and it sparked this new debt of mine haha.
Old Nov 20, 2013 | 11:53 AM
bobbyrandolph440's Avatar
My only question is why 9.6to1 compression if your going e85 ?
I was understanding e85 loves higher compression
Sent from my VS870 4G using Tapatalk 2
Old Nov 20, 2013 | 12:07 PM
1SlowSi's Avatar
I went with these because they were off the shelf and the next off the shelf is 11:1. I wanted 10:1 but I wasn't going to pay the extra $200-300 for it. I also chose 9.6:1 because with the head having been slightly milled/resurfaced, along with the block deck being done while sleeving, that is probably not 9.6 any more. I will never run a high compression motor again with E85 because with the intense amount of cylinder pressure and godly amounts of fuel needed at high power levels, E85 wasn't very easy to ignite even with the Boost a Spark turned up high. Also, after seeing several setups with various compression ratios, the power differences were not extreme enough to sell me on 11:1 again. Don't get me wrong, I enjoyed the 11:1 CR responsiveness but I think mine will still be peppy.
