850 whp Build - Quest for 9's - Completely New Setup
Looks like a good build, I like the photography work. I skimmed over the build list and the biggest thing that stood out was the turbo. You wont make 850whp with the S366. At full tilt it can get close, but I would say 800whp is what you will see at the most. If you plan to make a fairly reliable 850whp you will need something like the 67.7mm or 71mm.
Well 850hp is just a figure and I gauged that on Passmans 833whp @33 psi number. Honestly, 800whp is the goal and 850 was the max I would expect from this turbo. Hell, my 6262 was only rated for 700 and people have made 750-800hp from it.
Thought it would be somewhere the 10.5-11:1 range. Higher compression definitely helps to make the power, as more compression gives increased efficiency.
Just noticed you said you made a pull and blew everything up. Gave me a laugh and made me realize its been a long weekend.
Originally Posted by ScorpionT
Thought it would be somewhere the 10.5-11:1 range. Higher compression definitely helps to make the power, as more compression gives increased efficiency. Just noticed you said you made a pull and blew everything up. Gave me a laugh and made me realize its been a long weekend.
