About to prepare for more boost few questions
As title states I am getting the car ready for more boost and the car will be hitting the dyno this coming saturday.
Current setup:
- Completely stock 2004 longblock
- UR turbo kit
I am about to install the inlinePro 3mm Headgasket, ARP headstuds, ID1000cc, Skunk2 70mm, and SOS 3Bar
Whats the latest update on the 3mm headgasket argument? Clock the oem timing gear? leave it? I was planning on just installing the HG according to the manual using ARP torque specs and their supplied ARP bolt lube.
Any other suggestions? Any sealant on the HG?
Planning for 500-550whp on 93 octane
Current setup is yielding apprx 400whp
Current setup:
- UR turbo kit
^I have been following the 3mm headgaskey debate but race gas is not practical for my use. I just want a fast street car and don't care much for race gas applications. I have another f20 in my garage I plan to build in the future so even if the hg route doesn't last a long time it isn't of big concern
I just want to take any steps possible to prolong it's life. Some have had problems with the 3mm (some cases assuming hg failure when not) while others have been trouble free
Yes you do need to clock the timing gear, it is very easy if you have an impact or freind to help.
Thanks for the detailed response dsddcd
I purchased the throttle body for cheap so it wasnt exactly the largest investment, is it even beneficial to installing it? I havn't found much info on boost+throttle body on here to be honest although it seem to help other boosted vehicles.
Is the copper spray a component of the install that many insist on doing? Do the 3mm headgasket users find that the use of copper spray prolongs its life or is found to be the same?
Copper is spray has been used for years by lots of people. Many people use it for factory HG and aftermarket. It is more for the water and oil side rather than the combustion chambers.
if i could do it over, i would say F&*K the aftermarket HG and keep my oem one.
i dont have any problems with my cometic 2mm, but having the oem honda assembled setup where everything was made to fit together that way is absolutely best.
i dunno about the copper spray. honda doesnt use it.... AEBS doesnt use it, i dunno about IP. i would pass, but thats only my opinion.
