AC relocation
Old Feb 24, 2008 | 03:43 AM
Nyther's Avatar
No no thats not true yuri, the last time we hal -10 C was like 10 years ago global warming FTW!
Removing the ac compressor, condensor lines and radiator, how much is this? 60Lbs?
I think its smarter to remove the a/c while going turbo because you lose the a/c radiator thats in front of the oem radiator. better cooling?
Old Feb 24, 2008 | 04:10 AM
YuriArts's Avatar
Dude, we had -10 degrees 1 week ago at 01.00 at night when I was driving home.
I guess the winter in southern Holland is less cold ?
We go on vacations with the car so I would never drop the AC. And 60 lbs, so what? It's not a track car anyway.
I even have 2 subs and 2 amplifiers in the trunk..
Old Feb 24, 2008 | 04:17 AM
Nyther's Avatar
-10 degrees!? haha nop we dont have that in limburg
but with all that extra power what difference does 60lbs make...
but i guess it's better for the oem radiator to have better cooling without the a/c radiator blocking it
Old Feb 24, 2008 | 05:50 AM
misz's Avatar
AC is also a must for us hardcore hardtopers I will also reroute my ac.
Old Feb 24, 2008 | 07:37 AM
Spec_Ops2087's Avatar
Any updates with the WG?
Old Feb 24, 2008 | 09:53 AM
YuriArts's Avatar
Yup, it was installed yesterday. They sent me the wrong converter so we had to make one ourselves
The heating pipes were also in the way so they were moved a bit, the bracket changed.
There is an issue with the brakes, after that is resolved we'll take it for a spin and see if the problem is solved.
Old Feb 24, 2008 | 02:16 PM
Sounds good, looking forward to the results
Old Feb 24, 2008 | 09:04 PM
Did you port the hole in the manifold as well or just got an 38-44mm adapter plate?
Old Feb 24, 2008 | 11:27 PM
YuriArts's Avatar
I did order an adapter plate but they sent me the wrong one
So we had to make one ourselves.
The Manifold is not ported, see how this turns out first before we go that route.
Old Feb 28, 2008 | 09:25 PM
YuriArts's Avatar
Tested the car yesterday, no boost creep at all anymore
Why does inlinepro sent out their kit with a wastegate that's just too small?
