Accessory Power
I'm about ready to get this thing fired up finally...however I have a few questions left.
I've got a few items left to pull accessory power (switch power) to and I'm not sure the best place under teh dash to do that.
I was looking at a spade connector to shove in place of the fuse, but I'd like to keep my fuses in place.
I did buy a fuse looking block, that goes in place of the fuse, and has a wire coming out of it and the fuse plugs into it.
However I've bought 2 of them, and neither one worked, so I don't know what thats about.
So I'd just rather cut/splice into a factory wire that I know will work.
I figured someone would know a good safe place for me to pull some power from.
Thanks
Thanks
Originally Posted by dammitjim,Apr 8 2010, 05:27 AM
They come from Honda open like you see in the picture. A spade connector works great.
Thanks!
Use an ADD a fuse, they are simple and safe
http://www.amazon.com/Bussmann-BP-HHH-ATM-...e/dp/B000GKEXK2
I pulled the fuse, placed the fuse in the part, and put the entire thing back in.
Won't work, I put the wire directly in the slot were the fuse would go in the block and it works fine.
Thought it was strange.
However I noticed there are 2 slots on top of the part, maybe it needs 2 fuses?
I only put one...
