ACT HS1-HDSS clutch,good enough for 30r?
Plan to run a full race turbo kit with a 30r ish equivalent, .82 hotside. Was wondering if this clutch would suffice as I originally intended to use this with a supercharger kit. Websites rate this clutch at 380ft Lbs of torque, but wondering if anyone has any insight or experience with this clutch and turbo kits like the 30r. Thanks in advance!
K, another question. Should I install the clutch before the turbo, or should i just install the clutch while installing the turbo? In other words, does this clutch need to be broken in first?
Originally Posted by petawabit,Apr 30 2009, 12:41 PM
But that means I can't really tune right away, can I?
The ACT street clutch disc is for 382 lbs of torque. I have the same clutch and I'm right at 380 in hot weather. I've only had it with the turbo for a few weeks and it's holding fine so far.
It doesn't hurt to install the clutch first. Especially if you're doing it yourself. Give yourself time to break it in N/A and not a base map. But it may be cheaper if you're paying someone else to do the total install at once. my $.02
Edit: I also would want to drive around on the base map for a long period of time.
petawabit
Nov 10, 2009 09:38 AM
