act pp problem?
Old Dec 27, 2014 | 04:57 PM
AF_BLACKBURN's Avatar
Default act pp problem?
I'm installing my new act pp with new oem disc and bearings and fidanza flywheel. I've got the pressure plate bolted down tight and the Throwout bearing still jiggles in the pp. I can probably slip it through the pp with enough force. Idk what the problem could be. Any advice??
Old Dec 27, 2014 | 04:59 PM
s2klariat's Avatar
The throw out bearing is going to move around. The guide is on the transmission side, which keeps it centered.
Old Dec 27, 2014 | 05:01 PM
s2klariat's Avatar
Old Dec 27, 2014 | 05:05 PM
So its supposed to jiggle around??
If i center it i can almost push the bearing through the pp
Old Dec 27, 2014 | 05:06 PM
s2klariat's Avatar
Yes. Once the transmission is in place, the throwout bearing rides on the guide as shown in the picture above, and it stays centered.
Old Dec 27, 2014 | 05:07 PM
s2klariat's Avatar
Pictures? And are you using an OEM throw out bearing?
Old Dec 27, 2014 | 05:13 PM
Oem Throwout bearing yes.
Old Dec 27, 2014 | 05:26 PM
s2klariat's Avatar
The throw out bearing is going to wiggle around until you install the transmission. It looks like you might be able to pull it out, but once its on the bearing guide on the transmission, I assure you it will not. A better question is what type of grease do you have to grease the throw out bearing? The green Honda Urea grease is good stuff, highly recommend it. On the inside of the throw out bearing, there is a groove. Be sure to pack grease all the way around the inside of the bearing, inside that groove. Also be sure to grease the input shaft splines on the transmission, and then also the ends of the clutch fork before you click it back into place.
Old Dec 27, 2014 | 05:34 PM
I have the Honda stuff to grease it. Ill give it a try i guess thanks
