adding some things to run e85
Old Oct 22, 2010 | 05:40 PM
DFWs2k's Avatar
here's what i found about the AEM one:
"AEM billet aluminum adjustable pressure regulator.
The AEM adjustable regulator bolts directly to the stock Honda or the AEM high volume fuel rail. It is CNC machined from 6061 T-6 aluminum. The fuel outlet port is tapped to 9/16-18 threads, which allows the use of several different hoses ranging from the stock Honda fuel return hose to –8 AN hose. The vacuum reference is 1:1 ratio so for every pound of boost on a turbocharged or supercharged application yields a 1-pound rise in fuel pressure. The range of adjustability is from 20 PSI to the maximum the fuel pump can deliver."
i read that the bosch inline pump allows the fuel pressure to be 100 psi, so would this aem unit be good enough for 550 whp on e85?
link to what i'm talking about:
http://www.advancespeedshop.com/adjustable...1bk-p-2306.html
Old Oct 22, 2010 | 05:42 PM
DFWs2k's Avatar
also, does anyone have pictures of how they installed their bosch in-line pumps?
Old Oct 23, 2010 | 05:59 AM
1SlowSi's Avatar
Trust me, the AEM will not work for setting 100 psi base fuel pressure.
Old Oct 23, 2010 | 10:21 AM
m R g S r's Avatar
Weldon regulator is the Reg you need to set base pressure to 90+ psi
AEM and Aeromotive won't allow you to do that
Old Oct 23, 2010 | 10:58 AM
D1sclaimer's Avatar
I wish I would have bought a Weldon FPR instead of my Aeromotive. Weldon makes good stuff.
Old Oct 23, 2010 | 11:40 AM
DFWs2k's Avatar
Ok, and to confirm, Weldon.regulator requires use of a different fuel rail?
anyone know if it has a port for fuel pressure.gauge?
AaronT2433
Oct 22, 2015 06:05 PM
riceball777
Mar 16, 2014 03:45 PM
hondaguys2k
Feb 1, 2012 08:57 AM
adam_gipson
Aug 19, 2005 12:00 PM
CRX 18
Feb 8, 2004 02:37 PM
