Aem 1052 issues
I removed my old e-manage (huge headache) and installed the 1052 unit. My problem is that every time I go to connect it says buffer overrun error. And the unit goes offline, then immediately back online. It will do it 2-3 hundred times before the calibration can get transfered onto the box. Any way to remedy this. It slows down my ability to make changes considerably. Is it possibly a bad cable?
Josh
Josh
In your laptop, in control panel's device manager, under hardware, go to COM1 (or whatever port you're using) and reduce speed to 9600 Baud. It might help. Also, in AEMPro, check to make sure the speed is the same.
Originally Posted by InductionPerformance,Aug 21 2010, 10:59 AM
What cord are you using? Update the firmware as well. If you're using straight serial and the issue continues after updating the firmware post back
Originally Posted by jb34304,Aug 22 2010, 08:52 PM
I am on version 1.19
Report back
Originally Posted by wadzii,Aug 23 2010, 06:43 AM
what usb-serial adapter are you using?
buffer overrun is normally a usb driver issue.
