AEM 3 Step?
Old Jan 12, 2021 | 05:20 AM
RolanTHUNDER's Avatar
Question AEM 3 Step?
Anyone set this up? What is the 3rd step for?
Old Jan 12, 2021 | 11:23 AM
EOE's Avatar
EOE
3-Sep can be used as traction control. I've yet to configure it for someone however I'll test it shortly on my own car once I'm done upgrading my supercharger unit.
Old Jan 14, 2021 | 01:14 AM
Thanks for the info. I assumed its a rev limiter you can set higher up the rev range after your 2 step which you use to launch off the line so you can use the 3rd step for...hot boy stuff I guess lol. I'll be supercharging soon too. It's ready to be mounted but I need to upgrade my clutch first. Waiting on the ACT HD PP to be delivered.
Old Jan 14, 2021 | 03:59 PM
EOE's Avatar
EOE
Although fun, I don't setup a 2-step on a SCd setup as it is not good for SC gears.
I even soften rev-limiter for people, so much so you'll feel power loss thus suggesting it's time to shift. If you choose to push it, only then does the fuel cut comes in.
Basically, I'm a party pooper as I cater more to reliability and longevity folks with smooth power delivery and snappy part throttle. I stay away from tuning party tricks that bring all boys to the yard.
Old Jan 18, 2021 | 12:54 AM
I see.
Isn't fuel cut what Honda programmed into stock ECU's so at 9200 rpm the limiter will kick in and that will be fuel cut but not ignition cut?
Old Jan 18, 2021 | 02:11 PM
EOE's Avatar
EOE
Correct. Probably to preserve the valvetrain.
Old Jan 22, 2021 | 12:41 AM
Cool. I remember the stock limiter was quite harsh in terms of cut off. The car would almost pull back and then accelerate again. Now on AEM V2 its a much smoother limiter where the car doesn't abruptly pull back like stock. My tuner said he sets his limiters softer for that reason.
Old Jan 24, 2021 | 09:16 PM
yamahaSHO's Avatar
We use it on a drag car for traction control while keeping the massive turbo spooled in lower gears.
Old Jan 28, 2021 | 06:08 AM
That's cool. Seems to be most effective in that kind of scenario
winning
Forced Induction For Sale
Dec 18, 2016 05:26 AM
sick_AP1
50
Jun 16, 2016 12:29 PM
Sondra S2K
Nov 2, 2015 05:47 AM
