AEM boost gauge issue
Old Jun 5, 2012 | 11:58 AM
NH_s2k_Guy's Avatar
Default AEM boost gauge issue
Ran a track day yesterday. About 2 hours on track.
My AEM boost gauge seemed to be reading normally at the start of the day but by the end of the day it was all wacky.
When I left the track sitting at idle at a light, the gauge is reading 30 Psi!!!! I'm only set up for 8 psi of boost.
Faulty gauge? Wiring? Something else?
Old Jun 5, 2012 | 01:48 PM
sata3000's Avatar
I have same problem but it's opposite. Mine will only read fine at first then it gets hot it will read 14" of vacuum at idle. I don't think the car will run at 14" of vac
Sent from my Galaxy S II using Tapatalk
Old Jun 6, 2012 | 12:15 PM
PUNCHIN-IT's Avatar
Maybe a vacuum tube became loose?
I remember something similar like that happened to me and it was just a loose vacuum tube.
Old Jun 6, 2012 | 03:30 PM
starrman's Avatar
Guessing you already checked the sending unit and connection of line?
Old Jun 7, 2012 | 01:46 AM
cmn's Avatar
cmn
Mine is crazy as well. I think it was showing correctly three times in a couple of months. Other than that, it shows way too high. Hopeless.
Old Jun 9, 2012 | 06:31 AM
NH_s2k_Guy's Avatar
Seems to only happen in the heat. Was fine this morning.
Old Jun 9, 2012 | 06:51 AM
sata3000's Avatar
That's the same with me. Perfect in morning. 30 drive later and it goes out of wack
Wydget
Jan 2, 2012 12:59 PM
Shftat9k
May 24, 2009 09:01 PM
s2000Junky
May 8, 2008 10:24 AM
nMeOnE
Mar 9, 2008 05:04 PM
nMeOnE
Mar 9, 2008 03:47 PM
