AEM Dryflow 4" in Black
Old Mar 12, 2010 | 08:04 AM
JoeyBalls's Avatar
Thumbs up AEM Dryflow 4" in Black
A few questions guys
My turbo inlet is 4", so for the silicone coupling, do I order 4" or like 4.25"?
Also where do I get a BLACK 4" AEM dryflow filter, all I see is white ones (or so it says, "filter material white", I want black
Thanks guys
Old Mar 12, 2010 | 09:26 AM
camuman's Avatar
21-205DK 4 in (102 mm) 6 in (152 mm) 5.125 in (130 mm) 5.25 in (133 mm) Rubber 1.5 in (38 mm) 0 degrees
21-2059DK 4 in (102 mm) 6 in (152 mm) 5.125 in (130 mm) 9.188 in (233 mm) Rubber 1.438 in (37 mm) 0 degrees
21-3059DK 4 in (102 mm) 6.5 in (165 mm) 5.125 in (130 mm) 9.25 in (235 mm) Rubber 1.5 in (38 mm) 0 degrees
http://www.aemintakes.com/search/univcone.aspx
they all look grey color.
Old Mar 12, 2010 | 10:51 AM
spectacle's Avatar
Do NOT use the AEM filters, they melt. Use the K&N's.
If you need help finding the part numbers let me know
Old Mar 12, 2010 | 11:00 AM
ChefJ's Avatar
I haven't had any issues with melting on mine. Its the basic DRY filter. Flow has been outstanding and sees plenty of heat.
Old Mar 12, 2010 | 11:23 AM
boostedf22c's Avatar
I haven't had any issues with my AEM Dryflow filter either. Your filter shouldn't be in a position where it's getting hot enough to "melt"
You can purchase them through Jegs or Summit.
You would order a 4" coupler if that is the size of the inlet on your turbo.
Old Mar 12, 2010 | 12:09 PM
smirfs2k05's Avatar
Do they make one that's similar to oe where its plastic so my silicone elbow will slip over it.
Old Mar 12, 2010 | 12:21 PM
Spoolin's Avatar
Advance auto also carries the AEM dryflow filters.
Old Mar 12, 2010 | 12:25 PM
JoeyBalls's Avatar
great thanks, also I have one of those synthetic composite velocity stacks, mostly for "show" to use at meets etc............ will that melt if I match that baby up to the cold side of the turbo?
Old Mar 12, 2010 | 02:30 PM
dsddcd's Avatar
I think Mase got a bad batch but I am not sure.
Old Mar 12, 2010 | 02:32 PM
dsddcd's Avatar
I have ordered mine from their online store and recieved free shipping and the cost was within a few dollars of everyone else, might want to throw in a spare set of BXR8EIX plugs while you are ordering.
