AEM EMS + 2 Step
Old Jun 10, 2008 | 07:35 AM
kutsujula's Avatar
Default AEM EMS + 2 Step
I do not have 2 step/launch control setup on my aem ems. I'm trying to goto the track friday and im wanting to see if I can get this set up. Is there anyone that can help me through this?
Old Jun 10, 2008 | 07:47 AM
Spec_Ops2087's Avatar
Do you have an aftermarket valve train? 2-stepping is going to cause you to drop a valve with the stock valve springs (I think thats the part that fails).
Use it at your own risk.
Old Jun 10, 2008 | 07:51 AM
Soul Coughing's Avatar
my tuner told me a story about a s2000 he tuned that bent 7 exhaust valves because the 2 step was so aggressive. I have a two step on my car right now, but its not aggressive at all. I make about 3-4psi out of a 60-1! Not that i can really take advantage of it anyway due to weak parts in my drivetrain!
If you want to set it up. Go to 2 step wizard in the EMS software. The two step is usually setup around 5k rpms and you can change the timing and fuel and ignition. I would however think twice about setting it up if you haven't any experience!
Old Jun 10, 2008 | 08:17 AM
kutsujula's Avatar
Yep imma leave it alone after reading this thanks fellas!
Old Jun 10, 2008 | 08:19 AM
kutsujula's Avatar
So what technique are you using to launch at the track, im on 255/50/16 Mickey Thompson ET Streets....
Old Jun 10, 2008 | 09:32 AM
Never used DRs but there are people that bog at 6k dumps. Either rev her to 9 and hold on, or more nicely hold it at 6-7k and quickly slip the clutch out.
Old Jun 10, 2008 | 09:39 AM
passmans2kny's Avatar
then say goodbye to the diff
Old Jun 10, 2008 | 10:04 AM
kutsujula's Avatar
lol ill check back in friday night with results. street tire time sucked along with sixty foot
Old Jun 10, 2008 | 10:24 AM
i broke an axle doing a two step with VHT at the track! Either rev really high, or slip the clutch out the hole!
BTW, what were your trap speeds with street tires?
Old Jun 10, 2008 | 10:47 AM
btstone84's Avatar
i was reving to 8500 and still bogged a little bit. i would drop to 5000rpms.
