AEM EMS Owners- Engine Load vs. Boost Gauge?
Old Aug 26, 2008 | 05:13 PM
9kFever's Avatar
Default AEM EMS Owners- Engine Load vs. Boost Gauge?
I am having a little trouble. I have a mechanical Defi Boost gauge. On my factory pulley the boost gauge read about .5 bar and maybe a little more on cool nights. I dyno'd at church on that setup and his dyno said 7.2 psi. Now I have the 3.9" pulley and my defi says about .95 bar which is about 13.7 psi. Well at church it said 12.5psi. On my AEM EMS when I log I am seeing about 11-12 psi under the engine load readout.
Can anyone give me any input?
I am using the 3.9 pulley revving to 9300rpms.
Old Aug 26, 2008 | 07:40 PM
timg's Avatar
Remember, the boost gauge reads gauge pressure while MAP sensors read absolute pressure. Mechanical and electronic sensors are often different. I've never had good luck with dyno sensors matching any other EMS or boost gauge readings either. Altitude, temperature, and even weather tend to exaggerate the differences.
Tim
Old Aug 26, 2008 | 09:44 PM
Spec_Ops2087's Avatar
^^ Once again correct, no need to add anything else
Old Aug 26, 2008 | 11:48 PM
9kFever's Avatar
So what should I be going by? Basically I wont to know that my boost is what it supposed to be. 3.9 should be making around 14psi at 9300. It is according to the defi.
Old Aug 27, 2008 | 07:18 AM
Engine load is more for tuning as it takes a lot of factors into play, for simple "what am I boosting" a boost gauge should suffice.
Wydget
Jan 12, 2012 09:19 AM
Wydget
Jan 2, 2012 12:59 PM
Shftat9k
May 24, 2009 09:01 PM
s2000Junky
May 8, 2008 10:24 AM
nMeOnE
Mar 9, 2008 05:04 PM
