aem ems parity error?
Not for an s2000 but for a 98 supra. Put in the aem ems but getting a parity error and break error. things i tried
1.) 98 lab top with serial port
2.) xp with usb iogear usb to serial.
3.) change com settings.
4.) car does have ground and power
IM getting a long list of parrity error and sometimes break error. can someone help me out?
I can't be certain, but I think you need to change your serial port protocol.
One way to change parity is as follows:
1) Right-click "My Computer" on your desktop and select "Properties" on the menu that pops up.
2) Left-click the "Hardware" tab in the System Properties dialog box.
3) Left-click the "Device Manager" button on the Hardware tab.
4) Right-click on the entry for you com port and select "Properties" on the menu that pops up.
5) Select the "Port Settings" tab.
6) Set the parameters as desired and left-click "OK."
You'll have to figure out what the parity should be, because I don't know what the AEM EMS is looking for.
Hope this helps.
Hope this helps.
