AEM EMS talk.
I have had the my map for a while now and have had some issues with the tune.
First, sometimes when I accelerate and shift normal, the a/f will jump from 14.5 to 11.1 then back to 14.5 Second, my a/f ratio at idle will be real lean 16.1 when I start it up after driving the car. Its fine after a few minutes but the initial start is real lean after a drive. Warm up enrichment is fine and idle a/f is fine when first started. I tried to post in AEM forum but cant. Thanks |
What type of map are you running? Is it a straight forward table map or are you running boost comp?
It was full boost comp with throt inj correct. But that does not work that well and I plan on using a hybrid in the next couple of days.
Another question I forgt to ask was if our ECT temps are accurate or does it need tweeking like our AIT. I searched AEM forum but the site seems to be having trouble. |
It needs tweaking aswell. Reads about 20 degrees hotter than the car actually is. I have a map with the correct cals...pm me an email address and I'll send it to ya :thumbup:
On your map you have to play with the first few cells, add a little fuel, also have you tried adjusting the throttle ij correct? Or did you just have it set and never touched it again? |
PM'd you.
And yes I played with the thro inj correct table, but I read that cars with "crazy" all motor cams, such as ours can have some trouble using it. Fperra also had some issues and used a hybrid map. Makes more sense and will help me get the part throttle a/f that I want. My main issue that I want to solve is the a/f when shifting. I goes way rich when I shift normal. Example... drive slow up to 4000(a/f 14.5) shift, rpms hit 2000(a/f 11.1),put in 2nd and drive a/f are fine. I think its my fuel decel but not sure. Thanks again Scorpion |
Sounds like fuel decel, but I haven't played with that part of the software yet. I love the ems but damn you can get lost quick with it :) My car does the same with just a cell based map, I run around 14ish at part throttle shift and it runs down to the 12s then leans out. So if you figure it out...hook a brotha up :LOL:
I don't know what your guys problem is. :-) I got a map that is safe to run 8 psi of boost on with a GT30/71. Tuned myself. Runs 14 a/f at idle all the way to boost then drops down to 12.5 then at over 5 psi I have it drop to 11.8 I have 02 in closed loop mode, so if you dont' have a wideband that can be run in closed loop, ie installed all the time, this map won't work for you. I have a techedge wideband. The thing is so constant you could eat dinner on it. Just pm me
J. R. |
I have a wide band.
Not sure if I am following you, but my a/f are consistant at WOT and and are all most perfect when driving. My main concern is the huge change in a/f when shifting.I think its either fuel decel or fuel acel. Its not the individual cells. I just dont know where to start. |
So you have the same problem. For some reason I cant post on the AEM forum and the search lets me look at one page and thats it. Sucks. If I figure it out Ill hook you up!!! :D |
Warm up enrichment is fine and idle a/f is fine when first started. I bet you are getting a little heat soak and the engine is getting hot air for a little while after you've let it sit for a little while after driving. your other issue is probably decel fuel related, but you should be able to clean it up with the base map; unless you are running too large of injectors. |
