aem ignition driver install help
Old Aug 17, 2006 | 06:55 AM
GDM S2K's Avatar
Default aem ignition driver install help
Just tryign to get this in before the motor comes this week. on the actual harness where the plug for the coils are which is the poss and negative for putting the 954 coils on and this is a stupid question but I had a brain fart is cylinder 1 in the front or rear of the engine bay. I know I know. thanx for the help guys
Old Aug 17, 2006 | 06:58 AM
CaptKirk's Avatar
From what I remember, cylinder number 1 is always the one that is closest to the transmission... so #1 would be in the rear of the engine bay for us...
Someone correct me if I'm wrong.
Old Aug 17, 2006 | 07:03 AM
GDM S2K's Avatar
also to further my question is the blk yellow the signal wire? or the other wires with white and what is the solid black?
Old Aug 17, 2006 | 07:36 AM
John_Z's Avatar
No, #1 cyl is towards the radiator. #4 is adjacent to the firewall.
Old Aug 17, 2006 | 08:42 AM
kane.s2k's Avatar
#1 is towards the front and you take your ignition timing from cylinder #4
Old Aug 17, 2006 | 09:00 AM
GDM S2K's Avatar
so what color wires go to the new coils and what color do I tap for each coil with the ignition box
Old Aug 17, 2006 | 10:59 AM
CaptKirk's Avatar
Oops
my bad...
Old Aug 17, 2006 | 05:16 PM
fperra's Avatar
Check out this thread, it might answer your questions:
https://www.s2ki.com/forums/index.ph...&f=22&t=251743
Old Aug 17, 2006 | 05:58 PM
GDM S2K's Avatar
I got that much but I can figure out what goes where on the cbr plug. The Wire closest to the D in denso gets connected to? than the other wire gets connected to what color? thanx in advance guys
Old Aug 17, 2006 | 06:40 PM
fperra's Avatar
I'll see if I can take some pictures tomorrow.
