AEM serial gauge
Old Apr 28, 2014 | 08:20 AM
macdaddies911's Avatar
Default AEM serial gauge
If I am using AEM EMS V2, does the serial gauge need a separate wideband sensor.
Old Apr 28, 2014 | 08:32 AM
jdmdohcpower's Avatar
Yes it needs the uego sensor in the exhaust
Old Apr 28, 2014 | 09:12 AM
Redline S2K's Avatar
AEM part number 30-2310 is what you need.
Old Apr 28, 2014 | 09:28 AM
Thank you both
Old Apr 28, 2014 | 09:30 AM
Wow 300 for the gauge and 200 for the uego. I think for my SC set up I may just go with AEM failsafe, boost and AFR gauge.
Old Apr 28, 2014 | 10:45 AM
You still need it for the air fuel gauge, unless you're talking about picking up the stock narrow band signal which is not very accurate and a waste of a gauge.
If you want function and are boosted, accurate air/fuel and boost are gauges you should have. That's why it makes sense to get the serial gauge. With the uego sensor you will get air fuel and you can pick up so many others without much needed stuff, map sensor and oil sender are good to. That will give you air/fuel, water temp, oil pressure, boost, air intake temps and more in just one gauge. But, at the end of the day if its a street car, you can live with air/fuel and boost. Its at least good to know its running right and your belt isn't too lose causing low boost, or whatever.
Old Apr 28, 2014 | 11:38 AM
I think you'll still need the wideband adapter to see AF. Should have my iPod and module installed this week so you may be getting some PM's about install and programming.
Old Apr 29, 2014 | 02:51 AM
JJAUTOWERKS's Avatar
Former Sponsor
Or buy the wideband gauge and use what you need. Or buy the harness seperate and sensor seperate to save a few bucks.
Moddiction
Mar 1, 2016 05:51 AM
EvasiveMotorsports
203
Feb 25, 2015 08:31 AM
Moddiction
Jan 18, 2014 04:40 PM
dan_uk
Forced Induction For Sale
Oct 9, 2013 08:38 AM
