AEM Serial Gauge
Anyone using them ??? and where you put the gauge??? The reason I ask is because it come with some prety thick wire and I'm not sure where to install it.
or how to hide the wire
I believe that it is a 52mm pod which can be put into the audio control in place of the mode button, but you lose the dash control of your head unit. You can also purchase a gauge pod (www.scienceofspeed.com) if you have another gauge to go with it, or you can put it in the dash. If you're feeling creative you can put it in the center console where the cupholder is, or if you're feeling lazy you can simply put it on the dash with some double sided tape. The possiblities are endless man.
I am gonna get one becuase it will match my uego and I don't mind hte look of that. plus the ability to program many different settings makes it appealing. I am getting rid of my Spa Guages becuase after 3 sets of sensors they still refuse to read accurate temps.
It's fairly straight forward. Remove the panel, cut it with a dremel tool or something similar and mount it there with double-sided tape. I just used some stuff from Home Depot that is about 1/8 of inch thick with adhesive on both sides.
