AEM Truboost
Old Jan 19, 2011 | 07:06 PM
p0staboy's Avatar
Default AEM Truboost
Anyone here running the aem tru boost boost controller? I've bin told it has a boost by gear feature which basically sets a certin amount of psi per gear so you are acually able to hook. Is this true? If it is, is their like a button to disable the boost by gear option and just set it at a certin psi for every gear? Thanks
Old Jan 19, 2011 | 07:33 PM
Deception's Avatar
I dont own an AEM truboost, so I might be wrong, but Im pretty sure "boost by gear" can only be done through EMS. Mine was setup with AEM EMS & an electric boost solenoid. The truboost can do the same thing, but you need to set it up in your tune.
Old Jan 19, 2011 | 07:39 PM
p0staboy's Avatar
Hmmmm, I am getting a AEM EMS with my kit, so are you telling me I don't need the aem tru boost to get boost by gear?
Old Jan 19, 2011 | 07:53 PM
Deception's Avatar
Basically tru boost is a boost solenoid/controller & gauge rolled into one. The nice thing is you can raise & lower the PSI by pressing buttons on it while you're driving without a laptop.
But if you just want boost by gear & dont need it to be adjustable on the fly, get a MAC solenoid for $50 and save the money. Tru boost is $300 IIRC?
Old Jan 19, 2011 | 07:57 PM
p0staboy's Avatar
Well I don't mind spending the 300$ on a tru boost as it's as simple as a button to raise and lower psi. But I'm not sure how the boost by gear and the aem tru boost will work together? If I raise the psi on the tru boost will boost by gear still engage? Anyone running the aem tru boost that can chime in?
Old Jan 20, 2011 | 04:09 AM
dc2-2-ap1's Avatar
i was told the tru boost cannot perform boost by gear- i went with a gm boost solenoid (around 50) to do boost by gear.
i wish the tru boost could because it is a good value and a nice setup
Old Jan 20, 2011 | 06:44 AM
p0staboy's Avatar
So how does boost by gear work? Is it in the aem ems?
Old Jan 20, 2011 | 10:17 AM
Soul Coughing's Avatar
you're right, there is no boost by gear function on the Tru-Boost.
Old Jan 20, 2011 | 10:21 AM
its setup in the EMS, under the wastegate function. There's a thread about it on here somewhere.
Old Jan 21, 2011 | 05:58 AM
InductionPerformance's Avatar
Use the AEM EMS to control boost. If your tuner knows what they're doing it will be ten times better and a lot more flexible.
